SRS Volume Problem on Realtek HD
Hello
I have windows 7 ultimate 32 bit and i have installed SRS HD Audio Lab on my reltek but there is a sound problem
The volume comes low.......
plz help
Hello
plz help
Try this, switch your default playback device to your Realtek sound card. Then crank the master volume all the way up to 100%. Then set the default playback device back to SRS HD Audio Lab. This should fix the audio issue.
The Same Problem
Actually Its a Laptop And Its Sound Card Is A Stereo So Mebe thats a problem that my sound card is low quality one but on the stereo sound of my realtek the sound is great up to 100%.And The SRS is low till 30% or 40%
And i Have 5.1 surround speakers and its working to stereo mode not original 5.1
SRS is Good And Some how Tell Me the way to Get That System Volume to 100%...
I will be very thankfull to you for this act of kindness............
and also i got a prob that i cant open the SRS controll panel Can you Give me the Activation Key plzzz
And when i close the cotroll panel the voice suddenlly get full but not good
