Windows 7: SRS Volume Problem on Realtek HD
06 Sep 2010   #1
Aun123
Windows 7 Ultimate 32 bit
Hello
I have windows 7 ultimate 32 bit and i have installed SRS HD Audio Lab on my reltek but there is a sound problem
The volume comes low.......
plz help
07 Sep 2010   #2
Aun123
plz need help quick anyone
07 Sep 2010   #3
SRS Labs
Try this, switch your default playback device to your Realtek sound card. Then crank the master volume all the way up to 100%. Then set the default playback device back to SRS HD Audio Lab. This should fix the audio issue.
11 Sep 2010   #4
Aun123
The Same Problem
Actually Its a Laptop And Its Sound Card Is A Stereo So Mebe thats a problem that my sound card is low quality one but on the stereo sound of my realtek the sound is great up to 100%.And The SRS is low till 30% or 40%
And i Have 5.1 surround speakers and its working to stereo mode not original 5.1
SRS is Good And Some how Tell Me the way to Get That System Volume to 100%...
I will be very thankfull to you for this act of kindness............
11 Sep 2010   #5
Aun123
and also i got a prob that i cant open the SRS controll panel Can you Give me the Activation Key plzzz
And when i close the cotroll panel the voice suddenlly get full but not good
Realtek HD - Low Volume Fix
Hello there, Instead of replying to older posts i'll just create another one. I've seen few people having issues with low volume with Realtek HD, I was one of them. My sound "system" is just pair of headphones so 100% volume was not enough for me. So after few days of messing about I found an...
Low volume/sound limiter (realtek)
Realtek ALC662 + Windows 7 here. I've been everywhere, from BIOS, to new, old drivers, equalizing, desequalizing, been to every menu on sound I could find. And certainly deactivated that "conversation setting" supposed to bring your volume down when in calls. Yet, my sound is terrible. I'm...
Realtek high definition audio max volume is about 50% than before,help
hello. At some point I chose to reinstall Windows. I installed and updated all the drivers, etc and set the speakers up the same way as before. Only this time the audio was around 50% of the volume it was previously with volume up full. I reinstalled all audio drivers 5 times already, dont know...
Realtek HD Audio Very low Volume and Variable
Hi, Having a bit of an issue configuring my Realtek Audio Drivers on my computer. Originally I had a setup using an external audio interface (Desktop Konnekt 6), but I recently split my system apart so I have to start using the onboard audio on this computer once again. Originally I had the...
RealTek ALC888 - Low volume issue
First off here is what I am using Hardware: Windows 7 x64 RealTek ALC888 -> R2.70 drivers for Windows 7 64 bit. Headphones: Creative Fatal1ty Audio settings: Loudness Equalization enabled, 16bit 48000 Hz DVD Quality.
Realtek HD Audio volume
After i connected my speakers to my laptop(they were connected before to my computer) i have noticed a small difference in volume. On my laptop the volume is lower than on pc and i guess is because of the sound card and driver but i have everything at 100% . Could this difference of volume be from...
