No Sound from HDMI Port after installing ATI Radeon 5750 graphics card
Sun Moon Stars
10:53 PM
After I installed my new graphics card physically, I switched my display to a Sony LCD TV and plugged it into the HDMI port on the graphics card. After that, I installed all included device drivers and have since updated my Catalyst drivers. Still, I don't seem to have any sound from the TV, though I can still get sound by hooking up my speakers...
Despite that, I'd really like to get sound out of my TV. Any advice? Here are my specs:
Operating System
MS Windows 7 Home Premium 64-bit
Intel Core 2 Quad Q8300 @ 2.50GHz 37 °C
Yorkfield 45nm Technology
RAM
8.0GB Dual-Channel DDR2 @ 399MHz (5-5-5-18)
ASUSTeK Computer INC. CG5270 (LGA775)
Graphics
SONY TV @ 1360x768
ATI Radeon HD 5700 Series
977GB Hitachi Hitachi HDT721010SLA360 ATA Device (IDE) 44 °C
Optical Drives
HL-DT-ST DVDRAM GH40N ATA Device
Audio
High Definition Audio Device
Thanks!
Windows 7 Home Premium 64bitIntel Core 2 Quad Q8300 @ 2.50GHz8.0GB Dual-Channel DDR2 @ 399MHz (5-5-5-18)ATI Radeon HD 5700 Series
ASUS
SONY TV @ 1360x768
Check your sound and see if your device is disabled.
Systems 1 and 2: Windows 7 Enterprise x64, Wi...System 1: i7 [email protected], System 2: AMD FX-41...System 1: 8GB System 2: 8GBSystem 1: ATI FirePro V4800 System 2: Radeon ...
Dell and Custom
System1: Viewsonic HDMI 24"
10 MBPS
ASUS
SONY TV @ 1360x768
Sun Moon Stars, welcome to the forums.
Did you make sure to set the ATI HDMI Audio as the default playback device in the Windows playback properties?
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Thanks!
Can you give me a step-by-step on that?
ASUS
SONY TV @ 1360x768
Lemur's screen shot above, if yours is showing as enabled, click on it then click on "Set Default".
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Ah, yes, then they are all enabled.
Here's a screenshot for reference:
ASUS
SONY TV @ 1360x768
One very good reason you're not getting sound over HDMI, it isn't showing in the list. This is from mine,
and just like Lemur's shows as "not plugged in". That would be because neither of us are using the HDMI port on our cards. In your case you don't even have the ATI audio showing. Let's start with installing the drivers, use the full Catalyst Suite from here,
ATI Radeon™ Video Card Drivers for Windows 7 - 64-Bit Edition
and during the install when you get to the screen where it asks Express or Custom install, choose Custom. Then on the next screen it will show everything that will be installed/updated. If the audio portion was installed previously it will be greyed out but allow you the option of installing again by unchecking it,
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Well, then, here's something curious. When I downloaded Catalyst Suite again, and went through to Custom install, there was never an option to download an HDMI driver for some reason. Look here, these are all the options I got:
ASUS
SONY TV @ 1360x768
A couple of things to try,
1. Pull the card and clean the contacts (a pencil eraser is good for this, just make sure the bits are cleaned off after) and clean out the slot itself, and then re-seat the card.
2. Make sure that the extra power connector is plugged into the card.
then run the install again. If that doesn't get the audio portion to show up it is possible that you got a defective card (it happens).
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Also, please look in device manager and see if you have a yellow warning.
Dell and Custom
10 MBPS
Nope...
OK, will reply again once I've tried these things. In the event my card is defective, I bought from Best Buy... do you think they'll replace it?
ASUS
SONY TV @ 1360x768
Well, I cleaned the contacts, made sure the extra power chord was connected, and re-ran the installation, and still nothing. I suppose the next step is to call Best Buy and ask about warranty information?
ASUS
SONY TV @ 1360x768
There's an ATI HDMI device available from Realtek.
Realtek
After you accept the download agreement you will see the driver at the bottom of the Realtek driver listing. ATI HDMI Device (in red).
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
Realtek
Ap
Problem solved... thanks so much!
ASUS
SONY TV @ 1360x768
Hey, glad it worked... you never know.
The Realtek audio drivers must not include the HDMI port device for the ATI HDMI drivers to hook into, but that's just a guess.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
