Need help my sound
  1. Posts : 4
    Windows 7 Ultmate 32 bit
    Need help my sound
    Hello everybody
    I'm a new register, And i get an error with my Audio Service, It not running, I started every Dependencies service, but it still not working, I have read some the same error in this 4rum but i can not solves my problem. So i need any member help me. The computer had no sound is so boring
    P/S: First of all i get 1079 error and then i had 1083 error Messages:" The executable program that this service is configured to run in does not implement the service"
    Thanks you for your helping me:)
  2. Posts : 3,139
    Have you download the latest audio driver from Foxconn?
    Do you have any yellow warnings in device manager?
    When does your error pop up?
  3. Posts : 4
    Thank you for your repply!
    I have been download the latest driver from Foxconn and Realtek web site, It woring properly, but the Speaker icon in taskbar is red warnings and the message is "Audio service is not running". In additional, when the win7's setup complete all of them is working normally but when i update some drivers (my built-in VGA card, my build-in Realtek Audio, my build-in Infrared ). When i power the computer in the next day. I had the problem as i desbribed.
    Pls help me
    In the Computer Management / Services/ Window Audio Properties have a C:\Windows\System32\svchost.exe -k LocalService which is that right? And I added Local Service Account in Log On tab and then i start service again but unsuccesful
  4. Posts : 10,200
    WIN key | type Troubleshooting | ENTER key
    WIN is the key with the wavy flag.
    See attachment.
  5. Posts : 4
    I tried but it as my attachment
    Attached Thumbnails Attached Thumbnails Need help my sound-can-not-fix-problem.png
  6. Posts : 10,200
    And if you click on : View detailed explanation
    then what appears.
    Oh yes, View detailed information appears at the bottom and can easily be overlooked.
  7. Posts : 4
    Need help my sound-details2.pngThe Details infomation is as my attachments
  8. Posts : 10,200
    Excellent.
    I've never examined a Registry log.reg, but--
    could you zip that file for me and attach same to your next post?
    I will give you the approach I would follow, although my explanation is weak.
    I would go into device managment, and disable and remove the drivers for all devices which show a yellow triangle or worse yet, a red stop sign.
    Then I would shutdown 100% the computer. Don't just "hibernate' or 'sleep', but actually shut power off.
    Now power on the computer. MS will install drivers without any effort on your part. Let MS install drivers. Do NOT install any more drivers after MS finishes installing their own default drivers.
    Your sound will probably work now.
    Let me know the results and I'll suggest a change to MS update to guarantee that update fetches the latest updated drivers that MS has. These are, generally, not the very, very latest drivers from the manufacturer.
    Oh yes, to run device management:
    WIN | type DEVMGMT.MSC | ENTER
    You want to Right-click on the device with a yellow triangle and choose disable, if the option is there, choose Uninstall if the option is there.
