Age of Empire 3 No Audio
  1. Posts : 7
    Windows 7 Home Premium x64 Original
    Hi folks I need help. I installed AoE3 in my computer but when I restart, Windows Audio service won't run and all programs that checks system specs can't run. My Computer (the desktop shortcut) keeps on saying:
    "There is not enough free memory to run this program. Exit one or more programs, and then try again.
    But if I right click and select Open then it opens normally. What should I do?
    Extra info:
    Attempt to start Audio Service error:
    Package ID:AudioPlaybackDiagnostic
    Error code:0x8007000E
    Source:Engine
    Network icon keeps on showing not connected even when I am connected to a wireless network.
    I would repost this in the gaming section and see what the gamers say. Although the audio is affected, I suspect it has to do with the installed game and how it configured or reconfigured the PC. Probably if you uninstall the game and/or use System Restore and restore the PC back to a date PRIOR to installing the game everything else will work properly.
  3. Posts : 7
    Already tried
    Already tried uninstalling AoE III to no avail. Haven't tried system restore though. BTW, audio works in Ubuntu 9.10 fine.
  4. Posts : 7
    Windows Installer Service won't run.
  5. Posts : 8,135
    Can you run System Restore in Safe Mode?
    You can also try a Startup Repair see THIS
