onboard sound vs. Addon sound card
bassfisher6522
8:29 PM
NC
What would be the advantages/disadvantages of onboard sound vs a sound card? With a sound add on card are there headers for front panels connections.? Would I see/hear a big difference in the sound?
Windows 7 Ultimate 64 bitAMD Phenom II X4 965 Black EditionGSkill 4 X 2 GB PC 8500XFX Radeon HD 6790 D
Custom built
Gigabyte GA-MA790X-DS4
On board RealTek HD
Dual monitors:Samsung SyncMaster S20B300
1600 X 900
Seagate Barracuda 1TB (primary)
Seagate Barracuda 2 X 320 GB
Ultra X4 750 watt fully modular
Thermaltake Overseer RX 1 full tower
Core-Contact 92 mm CPU Cooler
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
It would depend on what you want from the audio or what applications you have for it. I have a home built using an Intel motherboard that has IDT (SigmaTel) HD audio on it. It's fine for most of the "listening" that I do However, I have a music program that uses MIDI and the default built in Windows/Microsoft GS Wavetable MIDI Synth is pretty bad. For that reason I have a SoundBlaster Xfi installed and SoundBlaster has on board hardware MIDI synths that are much better.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Systems 1 and 2: Windows 7 Enterprise x64, Wi...System 1: i7 [email protected], System 2: AMD FX-41...System 1: 8GB System 2: 8GBSystem 1: ATI FirePro V4800 System 2: Radeon ...
Dell and Custom
System1: Viewsonic HDMI 24"
10 MBPS
Depends on what you are looking for and as always what you are prepared to pay for it :)
To be realistic for most purposes the on-board chip's on today's systems are perfectly adequate for most peoples needs, if you are a serious audiophile or looking to use the pc for professional sound production, even DJing, that the flexibility and quality of add on external units are probably worth the extra cost and installation. In fact if you are a dj an extra card is virtually essential to allow off-line cueing etc.
    Ryzen 9 5950X, 3.8 - 5.2 MHz
    Asus Prime X570-Pro
    64GB [2 x 32GB] DDR4 3200MHz
    2 x 3840 x 2160 @60Hz
    Workstation Case [Matt Black]
    920 MB Down 50 MB Up
    Also run ...
    Nexus 7 Android tablet x2
    Samsung 10.2" tablet
    Wacom Expresskeys Remote
    Loopdeck+ Graphics Controller
    Shuttle Pro v2 Control
    Dell XPS 17 10750H
    Windows 11 Pro x64 Latest RP
    Intel I7 10750H 5.0GHz
    Dell XPS
    32GB [2x16GB] DDR4 2933 MHz
    nVidia GTX1650Ti 4 GB GDDR6
    Stock [Realtek] 4 Speaker
    3840 x 2400
    Stock - Active Fan Control
    Backlit + Various Logitech
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    Sony Z3 Android Smartphone
    Shuttle Pro v2 Control Pad
    10TB NAS
Another age old debate. Here is a thread on this very subject that is over 4 years old and up to 600 posts now,
Onboard Sound Vs. Add in Sound Card - Guru3D.com Forums
If you are gonna put your audio through $15 speakers, then forget the card and use the onboard audio chip.
So very true. Also if your going to use a digital connection (coax or optical, doesn't matter), then unless there is a feature that is on a sound card over onboard (DDL for example) just use onboard as it then comes down to what is connected at the other end.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
