Need HelpAudio Problem
jungleboy
3:13 AM
Need Help: Audio Problem
Hello everybody
I'm a new register, And i get an error with my Audio Service, It not running, I started every Dependencies service, but it still not working, I have read some the same error in this 4rum but i can not solves my problem. So i need any member help me.
Here i am attached some images of audio problem:
Windows 7 NVIDIA 2010 32-bit (6.1, Build 7600...AMD Turion(tm)64 X2 Mobile Technology TL-58(2...1024MB RAMNVIDIA MCP67M
Hewlett-Packard/HP Pavilion dv6700au
Windows 7 NVIDIA 2010 32-bit (6.1, Build 7600) (7600.win7_gdr.100618-1621)
AMD Turion(tm)64 X2 Mobile Technology TL-58(2 CPUs), ~1.9GHz
1024MB RAM
NVIDIA MCP67M
Generic PnP Monitor
1280 x 800(p) (59.969Hz)
Drive: A:
Total Space: 70.3 GB
File System: NTFS
Model: ST9160821AS ATA Device
Drive: C:
Total Space: 71.6 GB
File System: NTFS
Drive: D:
Total Space: 10.7 GB
File System: NTFS
54.0 mbps wifi connection
First, you didn't fill out the system specs, which is needed for someone to help you.
Also what happened prior to this error? Did you uninstall something? or install something?
One general suggestion, go to the Device Manager and check the Sound Device for any error code and post that. If there are no errors, click the entry for the device and then Left click "uninstall" (do not uninstall drivers) and then restart the PC and when Windows starts it should detect and reinstall the device.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Take a look at device manager to see if you have any yellow warnings.
Systems 1 and 2: Windows 7 Enterprise x64, Wi...System 1: i7 [email protected], System 2: AMD FX-41...System 1: 8GB System 2: 8GBSystem 1: ATI FirePro V4800 System 2: Radeon ...
Dell and Custom
System1: Viewsonic HDMI 24"
10 MBPS
Hi Guys,
I am a new member, I also having problem with my on board supremeFX Fi HD audio sound card that came with ASUS maximus II formula. Driver problem with soundMax. Try everything but could not get it fixed. By the way HOW can I insert images like JungleBoy so that the problem would be easier to explain and understand.
Thanks in advance.:confused:
win 7 ultimate 64BitsIntel Core 2 Quad Q660016 GB DDR IIClub GTS 250 Green edition
ASUS Maximus II Formula
16 GB DDR II
SupremeFX X-Fi Audio card
22" SAMSUNG SyncMaster T200HD
WD Caviar Blue WD5000AAKS - Hard drive - 500 GB x 3
"CoolerMaster Real Power M620"
CoolerMaster HAF 922
Fan cooling
id102, it would be better (forume ettiquette) to make a new post rather than hijack an existing post.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
