Microphone problem (Realtek)
  1. Posts : 4
    win 7 pro 64bit
    I have windows 7 64bit and I have:
    High Definition Audio Controller [1002-AA38] [NoDB] PCI
    Realtek ALC888/1200 @ ATI SB700 - High Definition Audio Controller PCI
    When I put in microphone, nothing happens and detect only:
    -Speakers (working ok)
    -Digital audio (s/pdif) (hight definition audio device)
    I'v download the latest realtek drivers (R 2.51)
    http://download.gigabyte.eu/FileList...tek_azalia.exe
    My motherboard is Gigabyte Ga-Ma770-DS3
    Picture:
    http://www.shrani.si/f/2P/um/NNoy3bt/sshot-1.jpg
  2. Posts : 186
    Windows 7 Enterprise x64
    Hi lebang and welcome,
    Check out and see if the MIC is ON.
    If the MIC is on,you probabally have the mic connected to the front panel,try to connect to the rear panel and see if the problem is solved.
  3. Posts : 4
    win 7 pro 64bit
    I'm heaving my mic. as it was working on win. xp in the back,
    but it is not working now.
    And also I don't have this settings.
    https://www.sevenforums.com/attachmen...io-manager.jpg
    How can I get this, because I think this could solve my problem.
  4. Posts : 908
    Windows 7 Home Premium
    The graphic you posted is showing -output- devices, the Mic is an input (recording) device.
    With your Mic plugged in, right click on the Microsoft speaker icon in the task bar, select "Recording Devices"
    Do you see the Mic there?
    If so, left click on it once then select the button that says "Select Default".
    Ap
  5. Posts : 4
    win 7 pro 64bit
    thanks for the answer.
    I don't know what kind of miracle happend, but two days ago when I chacked this settings I didn't have the microphone there (only Realtek digital input), but now it is!
    And working too :)
    http://www.shrani.si/f/3m/GD/2HEr6xUB/sshot-1.jpg
    Thanks!
  6. Posts : 7,683
    Windows 10 Pro
    Which Gigabyte board do you have? I have a GA-X58A-UD5 and there are instructions on page 128 on how to configure the Mic.
    If you don't have a manual, here's the link for my mine - check out page 128 - GA-X58A-UD5 (rev. 1.0) - GIGABYTE If you don't have a UD5, look for your manual.
    Sorry I don't use my onboard soundcard so I can't quickly say what needs to be done here.
    Sorry.
  7. Posts : 4
    win 7 pro 64bit
    no I have Gigabyte Ga-Ma770-DS3
    And the manual is a little useless, because I'ts all about win xp and not win. 7,
    And the programs on the CD coming with motherboard are not working.
  8. Posts : 908
    And working too :)
    Thanks!
    Perhaps the new drivers?
    Ap
