No sound in Front Panel Jack
  1. Posts : 8
    Windows 7 Ultimate 32Bit
    (Solved) No sound in Front Panel Jack
    I had this problem since i installed Windows 7 yesterday and my speakers in the back of my computer work fine, but just i cant put my headphones in the front panel. I saw several topics on here about it, but i read them and couldn't find a solution.
    I tried other audio codecs, i tried to Install Realktek HD Audio Codec/Driver so many times but everytime it installs and i restart, in device manger, its back to high definition audio device, which is the default from microsoft.
    Even when i try to install like like Update Driver > Let Me choose > Have Disk and such, extracting it and all that, it still doesn't work.
    Please help me, i have a 1GB Ram, and a 3.0GHZ processor. I can't spend my time breaking my back to bend over to put my headphones in the back.
    Thanks in advance.
  2. Posts : 10,200
    Ulrich,
    Please complete your system specs. This info will help us to help you.
    HOW TO FILL OUT YOUR SYSTEM SPECS
    In the line at the top of www.SevenForums.com you will see UserCP.
    That is an abbreviation for User Control Panel.
    Click on UserCP.
    In the left-hand column, under Your Profile you will see Edit System Spec.
    Click on Edit System Spec
    You can copy and paste from the output of Speccy, Speccy - System Information - Free Download to fill out much of the info. Be sure to use the Other Info section of your System Specs for such info as your optical drive, your wireless adapter, your speakers, etc.
  3. Posts : 8
    I couldn't really get to put in the Specs section so i just took pics from directx diagnostics and put em in on picture, i attached it.
    Attached Thumbnails Attached Thumbnails No sound in Front Panel Jack-specs.png
  4. Posts : 10,200
    Hundreds of SevenForum users have managed to use Speccy and cut/paste operations to fill in the system specs.
    Please cooperate. Thanks.
  5. Posts : 8
    Ok i've used Speccy and i copied and pasted the information, sorry for the lack of co-operation. Can you guys please help me?
  6. Posts : 8
    pleasee somebody reply and help me this is so urgent!
  7. Posts : 908
    Windows 7 Home Premium
    First,
    Don't install audio drivers randomly, your motherboard has a specific audio chip and it needs the drivers that are programmed specifically for that make & model.
    Windows has installed an HD driver and your speakers are working when plugged into the back, correct?
    The front headphone jack is blue, plug a set of phones in there.. then:
    Right click on the Microsoft Speaker icon in the task bar, select Playback Devices.
    Do you see "Speakers" with a green check mark (default) beside it?
    Is there an icon for headphones?
    If there's no other icons make sure that are all visable, Right click in the middle of the Playback Devices Window and enable both... Disabled and Disconnected devices.
    Any luck?
    Ap
  8. Posts : 8
    nothing happens actually, and the front jack color is green as well as the back.
    i attached a pic of what it looks like when i did what you recommended.
  9. Posts : 908
    Regarding the attached pic... did you have speakers plugged in the back at the time?
    Ap
  10. Posts : 8
    No i didn't
