sound blaster live does not work
St0rK
1:51 AM
hey my sound blaster live dosențt work at all it says that it is installed and everething seems fine ... just does not work
windows 7
windows 7
My Sound Blaster Audigy SE did not work under Seven either. I think it is too old, and there are not drivers for Vista or up.......
~Lordbob
Windows 7 Ultimate x64, Mint 9Intel i5-2500k2x 4Gb Corsair VENGEANCE DDR3-1600NVidia GeForce N260GTX Twin Frozr
Hera
Intel i5-2500k
ASUS P8P67 Pro
Realtek HD OnBoard Audio
ASUS 24" Monitor
Cooler Master Haf 932
Fans
Razer Tarantula
Razer Lachesis
not fast enough
As far as that SB Live goes Creative will never release a Vista or Windows 7 driver for it, as they declared that card (and all other Live series cards) EOL a long time ago. best I can suggest is to try this one,
SB Live! series Support Pack 1.0 (04/04/2009) - Sound Blaster - Creative Labs
If that doesn't work for you it is time to either,
1. Ditch the card and get something that will have Vista and Windows 7 support
2. Ditch the card and go with onboard if it is supported
3. Ditch Windows 7 and/or Vista and go back to XP if you want to continue using that card.
Lordbob you're not quite in the same situation as your card should continue to receive support as the X-Fi Xtreme Audio is basically the same thing. That being said if you haven't tried them yet there is a modded set for that serie4s of cards as well,
SB P17X Series Support Pack 1.6 (05/14/2009) - AudigySE/Value/LS_Live24bit_X-Fi XtremeAudio_SB5.1VX - Sound Blaster - Creative Labs
bit of a PITA to install if you already have previous drivers installed, but probably worth the effort.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Well, there were not drivers, but I also suspect it is broken so.........
~Lordbob
Hera
Intel i5-2500k
ASUS P8P67 Pro
ASUS 24" Monitor
Fans
Razer Tarantula
Razer Lachesis
not fast enough
I believe in many cases you can still find the drivers Dell offers for those cards and they still work.
Otherwise you can hunt on the internet for later Creative drivers that others have made compatible, especially if you need 5.1 surround, etc.
Windows7
Windows7
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Hera
Intel i5-2500k
ASUS P8P67 Pro
ASUS 24" Monitor
Fans
Razer Tarantula
Razer Lachesis
not fast enough
Sound blaster not working with Windows 7
I sort of found a bypass for this problem. It may not work for everybody but it is good enough for me. I went into the BIOS and changed the settings so I am making use of the 'soundcard' on the mother board.
I plugged my speakers in after finding the right jack, Windows installed the drivers and I now have sound.
When Creative gets around to providing a working driver I will swith back.
Windows 7overclocked 3.3 Gh4GBNVidia 8800
Dell XPS 710
overclocked 3.3 Gh
Intel
4GB
NVidia 8800
Soundblaster X - Fi
Dell 2701
3 160 GB 10K and 1 400GB
You could just take the card out and use onboard sound.
~Lordbob
Hera
Intel i5-2500k
ASUS P8P67 Pro
ASUS 24" Monitor
Fans
Razer Tarantula
Razer Lachesis
not fast enough
KX Project drivers work just fine in Vista and 7 :geek:
Win7/Vista/XP/Linux3.8 Dual Core / 1.6 Dual Core2GbRadeon X550 / Onboard
Win7/Vista/XP/Linux
Gigabyte / Toshiba
2Gb
Creative SB live / Onboard
Viewsonic VA1701 Dual / Notebook
1280x720 / 1280x800
2x 160Gb SATA
2x 500Gb SATA
480W
Mecer
Air
try this.. lordbob75
sorry for the poor english...
SUCESS INSTALLATION for Creative SB Live! 24-bit (CA0106) in "WINDOWS 7"
Integrated Audio Processor on MSI motherboard K9N DIAMOND (MS-7226)
(VERY IMPORTANT) HOW TO INSTALL (FOLLOW THE EXACT STEPS)
Go to Creative Sound Blaster - Sound cards for gaming, movies and music listening >
SUPPORT >
SOUND BLASTER >
If your product is not listed above, please click here. >
select LIVE! >
select live 24-bit (no external) >
latest downloads >
select "Creative Sound Blaster audio driver 1.04.0090" > download it.
(do not install direct from the .exe file downloaded)
(if you don't have winrar) Install the WINRAR
right click >
select EXTRACT TO SB24_PCDRV_LB_1_04_0090 > (or any local)
enter in this new folder >
enter in "DRIVER" folder >
double click in the SETUP file >
the installation will be lauch...
(the installation may be give few or much minutes or the system may be show the message
"not response" - DON NOT FINISH THIS PROCESS - wait for the complete install)
restart...
(IMPORTANT)
if the atualization Sound Blaster software appear, click in CANCEL... END.
(if you choose another option, will give the BLUE SCREEN OF THE DEATH)
Here is in full functionally. OK.
Filesize : 44.15 MB Download
Release date : 2 Jul 09
File Name : SB24_PCDRV_LB_1_04_0090.exe
This download is a driver providing Microsoft® Windows® 7 and Windows Vista® support for Creative Sound Blaster® Live!® and Audigy® series of audio devices. For more details, read the rest of this web release note.
This download supports the following audio devices only:
* Sound Blaster Live! 24-bit
* Sound Blaster Audigy Value/SE/LS
Requirements:
* Microsoft Windows 7 64-bit, Windows 7 32-bit, Windows Vista 64-bit with Service Pack 1 (SP1) or Windows Vista 32-bit with SP1
* Sound Blaster audio devices listed above
Notes:
* This driver is only for the Creative Sound Blaster audio device listed above.
DO NOT install this driver for other Sound Blaster audio devices.
* To install this driver
1. Download the file onto your local hard disk.
2. Close all other Windows applications.
3. Double-click the downloaded file.
4. Follow the instructions on the screen.
WINDOWS 7AMD 64 X2 4000+2GB DDR2 667MHZGEFORCE 8600 GT FATALITY
MSI
WINDOWS 7
AMD 64 X2 4000+
K9N DIAMOND BIOS 1.7
2GB DDR2 667MHZ
CREATIVE SOUND BLASTER LIVE! 24BIT INTEGRATED
SAMSUNG LCD 17"
SATA 250GB
Kamaradodesert, thanks for the long write up.
I have long since ditched that card, and my onboard motherboard audio is of muchbetter quality than it ever was. So no worries there.
Thanks anways ;)
~Lordbob
Hera
Intel i5-2500k
ASUS P8P67 Pro
ASUS 24" Monitor
Fans
Razer Tarantula
Razer Lachesis
not fast enough
hello there my sound blaster does not work also ...i have both windows xp and windwos 7 on my pc..if i run windows xp everythign is fine but if i run windows 7 i have no sound..i have done everythign i know and have read about to fix it and nothin workds...ive downloaded over 30 different drivers non worked....when i check my device manager is said im running creative sb 5.1 but when i check it another way it said im running sb live series (wmd)...i am lost on how to get souind... i have no sound at all on windws 7 and when i try to run the auto update on the creative website it said i dont have any of there products but i go back to windows xp and auto update and it said im running creative sb live ...i have tried evey suggestion on this forum and nothing works i cant even get alil sound...im half temped to take windows 7 back and go back to xp if anyone could help it would be appreciated...i even went the dell website and downloaded every driver for my exact model and that didnt work...ive tried all the sb live drivers and theyt all say i have the wrong os or doesnt work on this os....and there seems to be no wsuch thing as a 32 driver all im finding is 64 same as what most ppl have said on here...i have even sent creative a email stating my problems and have yet to hear anyhting back...bottom line i need to know y one min i have a sb live series (wmd) then a sb live 5.1 im pretty sure it dont matter b/c there both a live series but dont know what else to do ...not exxagerating ive treid everythign ive read about and every single driver even remotely close to my car from the creative website...please help sorry if all this is confusing ...
windows 7 ultimatepentium4
dell
windows 7 ultimate
pentium4
creative sb live series
;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj;osdfjslpdifjrsdl;afjsd;alfjdspkfsda;lfjsdl;fjdsa;lfj
Oh dear lord, if you do a search you'll find 50X threads to this topic.
http://www.sevenforums.com/sound-audio/16690-kx-audio-drivers-emu10k1.html
That's my thread.
http://www.sevenforums.com/sound-audio/2606-soundblaster-live-emu10k1-terrible-sound.html
That's the FIRST google search for Sound Blaster Live Windows 7
Repeat: FIRST GOOGLE SEARCH.
[edit] Again, SBL was dropped after WinXP. Meaning ALL THE DRIVERS FOR THE EMU10K1 and EMU10K2 chipsets are BROKEN INTENTIONALLY. They want people to start using the XFI series cards. That is why you get the crackeling and massive bass problems.
Windows 7, LinuxAMD Phemon II x2 3@37501G Crucial 16668800GT OC (custom OC)
Windows 7, Linux
ASRock M3A770DE
1G Crucial 1666
Sound Blaster Live! (never changes!)
Vivitron 22"
1600x1200
Western Digital 120G/160G SATA
Maxtor 80G IDE
450w
Unknown
Custom Air cooled
Logitech M-BZ15A Laser
Cable 10mbit
OMG! :shock: Don't people even read the preceding messages in the same thread? :eek:
Yes, SBLive series drivers was discontinued after XP, but KX Project still carries on.
Win7/Vista/XP/Linux
Gigabyte / Toshiba
2Gb
1280x720 / 1280x800
2x 160Gb SATA
2x 500Gb SATA
480W
Mecer
Air
Exactly, we need somebody to Pin a thread about how SBL was discontinued!!! WHY OH WHY every day there is at least 1 new thread about SBL not working.
Windows 7, Linux
ASRock M3A770DE
1G Crucial 1666
Vivitron 22"
1600x1200
Maxtor 80G IDE
450w
Unknown
Custom Air cooled
Cable 10mbit
Try this guys, worked for me...
Also had this problem, heres how I fixed it...
Driver used (SB24_VTDRV_LB_1_04_0090.exe) available from creative.
Install and when done go to Control panel, Manage audio devices.. This should display a sound window with devices listed, select SB live and in bottom left corner click configure. Should be pretty much self explanatory after that.
WIN10 junk & WIN7 PRO 64bitAMD Ryzen 7 2700X Eight-Core ProcessorCorsair LPX Vengeance 32693MB (3000)NVIDIA Geforce GTX1060 6GB
ROG Crosshair VII Hero
Soundblaster Z
Acer S271HL 27"
2 x GIGABYTE 250GB SSD
1 x SAMSUNG EVO 250GB SSD
1 x SAMSUNG EVO 500GB
1 x TOSHIBA 3TB P300 HDD
Thermaltake Toughpower Grand RGB 850W Gold Full Modular
Sahara P75 Full ATX RGB
6 Pirate True RGB 12cm fan
Logitech K740 illuminated
Logitech Darkfield Performance MX
100MB
Kaspersky
Waterfox and the other lesser known :-)
sound card problem in windows 7
hello guys, can someone help me work my sound blaster live the model is SB0220 on my windows 7. i want to make it work but no matter drivers for win 7. the windows isnt digitally signing my soundcard. any help and suggestion are welcomed! hoping to get some reply from you guy
windows 7 32 bit
windows 7 32 bit
Microsoft Windows 7 Ultimate 64-bits 7601 Mul...Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz8,00 GB(1) Intel(R) G41 Express Chipset (2) Intel(R)...
Microsoft Windows 7 Ultimate 64-bits 7601 Multiprocessor Free Service Pack 1
ASRock G41MH/USB3.
8,00 GB
(1) Intel(R) G41 Express Chipset (2) Intel(R) G41 Express
(1) VIA High Definition Audio (2) Intel(R) High Definition
S24B350 Samsung
(1) ST31000528AS ATA Device (2) Generic- Compact Flash USB Device (3) Generic- MS/MS-Pro USB Device (4) Generic- SD/MMC USB Device (5) Generic- SM/xD-Picture USB Device
ZoneAlarm Free Antivirus + Firewall version: 12.0.104.000 Vs
Found another official one Customer Support: Downloads However you must install this one in advised mode The game port seems to be installed, but I can't test it. Ignore the warnings while installing.
ASRock G41MH/USB3.
8,00 GB
S24B350 Samsung
