Windows 7: No Audio Output Device is installed
06 Oct 2010   #1
SJin1993
windows 7 ultimate x64
Few days ago, I had to change my motherboard due to some error from MSI to ASUS P5NSLI. After installing Windows 7 Ultimate x64, I found out that my sound wasn't working. I tried installing Realtek HD and the AC '97 with no luck.I used the program HWinfo32 to figure out my audio adapter, but it says unknown or none.
Help please ;(
Motherboard: ASUS P5NSLIProcessor: Intel Core 2 Duo E7400 @2.80Ghz.
Memory: 2GB
OS: Windows 7 Ultimate x64
06 Oct 2010   #2
SJin1993
sorry its been solved, the audio setting was disabled in bios
No Audio Output Device is Installed
I believe this is an issue regarding an update. I had this issue before and did a system restore to back before I had installed a certain program, and the issue went away. Now however, I do not have a restore point that will go far enough back. I started up my computer today and I was hit...
Drivers
no audio output device installed
This is my wife's sony vaio, and she has had this problem with no sound on her laptop, when checking the volume control it says no audio output device installed. In device manager it says that she has Intel display audio. I need major help here please.
No AUDIO OUTPUT DEVICE IS INSTALLED
No AUDIO OUTPUT DEVICE IS INSTALLED, this is the message l got on sound icone since l installed windows 7 l have downloaded it several time the latest one it shows on control panel but not on device manager, l guess this is not really installed but l keep installing it and restat the laptop...
No audio output device installed
I bought a generic computer. It had windows vista installed and it used to display a message that No audio output device is installed . I recently installed windows 7 home premium 32 bit on it but it still says the same thing. I went to properties of it and found following error message.This device...
No audio output device installed...Tried everything, need some help.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound again...lol Hi, I have had this problem now for a couple of months. What I have tried: Reinstall windows 7 Update bios Install the realtek high definition audio...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
