Sound Card low Output
youllbelost
Goofy Goosebumped
Power User
2:12 AM
India
My Mom got her PC repaired at a crappy shop. He tricked her into changing the sound card as a problem to the slow speed of the PC.
But, he installed a good one(Creative SB Live! series)
(He Didn't gave her the box of the same)
Now, The problem is that it is giving out extremely low output.
I have checked the system sound control. But i cant find Why the hell it is giving such a low output.
I installed the latest drivers by Driver_Easy(Because i couldn't find the drivers at the site).
Help please.
YBL
[Attached is the description of my sound card. ]
Dual Booting Windows 7 64-Bit Ultimate Editio...AMD Phenom X4 9254gb DDR3 G.skill RipJawsATI Radeon HD 6770
AMD _(Assembled)_
Dual Booting Windows 7 64-Bit Ultimate Edition and Fedora 16.
AMD Phenom X4 925
MSI 785g-E53
ATI Radeon HD 6770
Realtek
Dell IN2020M LED
1600*900 20"
Seagate 500 Gibs
External 320 Gb Western Digital(Got Glitchy)
Cooler Master
Cooler Master
Cooler Master
Logitech K100
Razor Death Adder v2 3500 dPi (Razer Goliathus Pad)
Back to college Internet with Cyberroam X|
Going by the DevID in that screen shot it is the Dell version of the Live 5.1, which doesn't work with the regular Live drivers. For that card (at least on XP) you need the one here,
Creative Worldwide Support > Sound Blaster Live! 5.1 Digital (Dell)
Click on the Driver link to show them all and the one you want is,
(Dell) Driver Install Pack 2 – 10 Languages
File Name : SBL5DL_DRVPACK_LB.exe
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Does not increase the sound output.
Its like a whisper.
sad.:confused:
AMD _(Assembled)_
AMD Phenom X4 925
MSI 785g-E53
ATI Radeon HD 6770
Realtek
Dell IN2020M LED
1600*900 20"
Seagate 500 Gibs
Cooler Master
Cooler Master
Cooler Master
Logitech K100
i know its not related to Windows 7 but please help if you can.
ive gotta fix it before 11th.
Help!!
AMD _(Assembled)_
AMD Phenom X4 925
MSI 785g-E53
ATI Radeon HD 6770
Realtek
Dell IN2020M LED
1600*900 20"
Seagate 500 Gibs
Cooler Master
Cooler Master
Cooler Master
Logitech K100
What are the specs on mom's computer? And what is/was wrong with the onboard sound?
truth be told, no it isn't. That card was a Dell OEM card only, to the point that it had its own drivers that only worked with it and could not use the regular SB Live drivers. Not too mention the fact that it is somewhere in the vicinity of close to 10 years old.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Thanks for replying.
Didnt knew that. Mom's specs are.:
Mobo.Intel 845GL
Pentum IV Willamette
(ask anything else)
About the card there was no problem that i knew of in the previous card.
but that card was surely older than this one.
YBL
AMD _(Assembled)_
AMD Phenom X4 925
MSI 785g-E53
ATI Radeon HD 6770
Realtek
Dell IN2020M LED
1600*900 20"
Seagate 500 Gibs
Cooler Master
Cooler Master
Cooler Master
Logitech K100
Both of similar vintage. If there was nothing wrong that you know of with the onboard, it sounds like where you took it is trying to dump old obsolete hardware. Hope you didn't pay too much for the card.
I would start with uninstalling any and all Creative software and drivers, make sure the onboard is enabled and then try this,
Intel® Driver Update Utility
If that doesn't work going to need the full make and model number of the motherboard (chipset isn't quite enough to go on) to see which onboard audio it has. If you can't find it on the motherboard this should be able to tell you what it is,
CPUID - System & hardware benchmark, monitoring, reporting
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
