Windows 7 start up sound/login sound
  1. Posts : 39
    FreeBSD
    Hi, iv just installed a fresh copy of windows 7 ultimate, and iv noticed something strange with the startup/welcome sound.
    The sound that windows plays to welcome you to the desktop seesm to execute before I even type my password in, and when I do type my password in, it plays the sound when you'v locked your PC and to log back in, its that same one.
    Is this the same on your PC's? Has it been desgined to play like this?
    TIA.
  2. Posts : 72,046
    Hello John,
    In the Sound scheme settings, you actually have 3 different sounds for this. One is the Windows Startup sound, Windows Logoff sound, and the other is the Windows Logon sound. You can change or turn them off.
  3. Posts : 39
    FreeBSD
    Brink said:
    Hello John,
    Thanks but what I want to know is the sound that first appears when you log into windows from a cold boot .... does that execute straight away at the password prompt or only after you type in the password on a default configuration of windows 7?
    TIA
  4. Posts : 72,046
    It plays the "Welcome" sound straight away for me, then the "Windows logon" C:\Windows\Media\Windows Logon Sound.wav sound right after logging in.
  5. Posts : 39
    FreeBSD
    So just for clarifcation, it plays the welcome sound straight away at the password prompt? Then when you type in your password and login in it plays the C:\Windows\Media\Windows Logon Sound.wav correct?
  6. Posts : 2,259
    W7 Professional x64
    Yes, the welcome sound plays when the logon screen shows up, and the logon sound when I enter my password and the desktop shows up.
  7. Posts : 72,046
    Correct.
