Solved very low sound
mikabomb
1:39 PM
my sound card is an Intel High Definition Audio made by Microsoft. i can't find any drivers on their site - just a doc [here]. and even then the doc doesn't apply to windows 7. all of my levels (including my master level) are turned up to the max. my speakers are correctly set as my default device. the sound for my speakers are on dvd quality. my volume is at the max and i can barely hear it over my desk fan. any help would be great. thanks in advance.
Windows 7 Home Premium 64 bitIntel Core i7-3770K @ 3.5 ghz16.00NVIDIA GeForce GTX 680
Digital Storm
Sound Blaster Recon3D
As this is a MAC it may be better to post this on a MAC forum.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
i'm pretty sure this is a windows problem. i have full sound on my mac side and i just upgraded from win xp and my sound was fine there as well.
Digital Storm
You will need a Windows 7 (or at least a Vista) sound driver, if available. If not you may have to do what many of the Windows XP users that upgraded had to do - install a Win 7 compatible sound card. There is a lot of older XP hardware that there is no Vista/Win 7 drivers for and the old XP sound drivers won't work. I do a lot of support on the Dell users forum and there are many posts on there about users having to install new sound cards.
Vista/Win 7 handle some sound functions differently and the reason some XP hardware and drivers will not work. I know, forced obsolesence. In order to take advantage of newer technologies some older hardware falls by the wayside.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
thanks much. i finally fixed it by downloading the latest Realtek driver.
Digital Storm
Cool. Your original post stated a different sound module.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
