less /unsatisfied sound output of realtek alc 892
vinodh
11:03 AM
Hello
I've bought a new system with AMD athlon ll x635 2.9ghz , motherboard TA890gxe ram 2gb kingston . I've installed Windows 7 x64 and i've also installed all the drivers provided by the biostar TA890gxe motherboard CD.
The TA890gxe has realtek alc 892 codec in . As i said i've installed the drivers from the motherboard cd. The problem is sound is not satisfiable . I primarily use headphone to listen to music and others. I dont feel the bass in my headphones and the volume seems to be normalized. My headphones were good absolutely good but i get less volume and less voice...
PLease help do have to go back win xp or install latest codec or do something else. please do provide some insight into this
Thanks In Advance
windows 7 ultimate x64AMD Athlon ll x6352gbATI 4290
AMD Athlon ll x635
biostar ta 890gxe
2gb
ATI 4290
realtek acl 892
I would first look for updated sound drivers and try them. If the drivers were specifically for XP that can be a problem due to Vista/Win 7 handling some audio functions differently. Look for a Win 7 or at a minimum Vista sound drivers.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
The drivers are for windows 7x64 ... the cd showed this info " Windows 7 x64 "on the screen and scanned for devices and drivers ...... that means ive installed the one intended for win7 ..........
Sound i'm not really happy with. I unable to enjoy the bass
AMD Athlon ll x635
biostar ta 890gxe
2gb
ATI 4290
realtek acl 892
First, have you made adjustments with the built-in equalizer?
If you right click on the MS speaker icon in the task bar you can select "playback devices" then select the default output device (green check mark) and select the "Properties" button, go to the enhancements, select "Immediate Mode" if you have it.
Look at the enhancements do you have one called "Loudenss Equalization", is it active? if so, uncheck it. That will stop some of the normalization you hear. Do you have an EQ, adjust it to your preference... also selct NONE for any of the Playback Environments.
If you're using WMP don't forget it also has enhancements... turn them all off.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
THanks aaaaaaaaaaaaaa lott Aphelion it works.....
thank you
AMD Athlon ll x635
biostar ta 890gxe
2gb
ATI 4290
realtek acl 892
