Window 7 audio not working please help !!
Page 21 of 23 FirstFirst ... 111920212223 LastLast
  1. Posts : 3,612
       #201
    ipodtouchme said:
    brianzion said:
    okey dokey let me no if you get stuck the forums are always here you have my email keep the receipt
    some advice in another thread Creative Sound Cards.
    thanks bRIANZION !!! <3 hope the sound card work or eles ehhhhhhh there goes a a few hundred to my comp
    shop around mate dont go to mad no more than $100 just check it will work with the specs and check the speaker leads etc check! check! check!
  2. Posts : 328
    windows 7 home premium 64, and Windows 10 64 bit
       #202
    What looks confusing to me is that there is a sound card listed as via HD audio yet I did not see the correct control panel window for the settings to direct the output for the sound. I feel sure that the AC97 is not plugged in and the HD plug is inserted in the MB. This just looks like the drivers were not installed correctly.
  3. Posts : 104
    Window 7 Ultimate 64bit
       #203
    then can you help me ? tell me how to install and that cause i tried so many times and failed .....
  4. Posts : 3,612
       #204
    hello have we tried looking in the services to make sure you have not missed anything not running at start up ?
    what DirectX do you have installed? go to control panel> performance information> and tools and click advanced tools> click view advanced system details in system information open components in the tree on the top left and click on sound device , and see what windows tells you post a screen shot if you will.
    Attached Thumbnails Attached Thumbnails Window 7 audio not working please help !!-brys-sound-device.png
  5. Posts : 328
       #205
    I had this problem myself. I honestly do not recall the exact steps I did to fix it. I did a complete uninstall of everything and then allowed windows 7 to do the install and that did work but I think you already did that. There is a conflict between the drivers for sure. This was before I installed the Creative Titanium card, so I do understand what your problem is. I am sorry I can't just fix it for you but I am trying to recall what I did that worked.
  6. Posts : 104
       #206
    I seee maybe my comps just sucks lol....... well wait untill i get the sound card see if it works. but thanks for letting me know
  7. Posts : 3,612
       #207
    Creative Titanium card so how does this card perform for you?
  8. Posts : 104
       #208
    would my sound come back if i get the createive titanimu card ?
  9. Posts : 3,612
       #209
    hello hello:) well i cant see no reason why not its a shame to take this step and spend money i no but as my opinion i would try it
  10. Posts : 104
       #210
    Getting Creative PCI-E Titan-Co Titanium sound card now !!
