Windows 7: Absurd Audio problem with Audigy 2 ZS
22 Oct 2010   #11
Windows 7 Ultimate 32bit
Sry, did you read my EDIT above?
22 Oct 2010   #12
Microsoft MVP
Win 7 Ultimate x64
Have you tried it after cleaning out those folders I mentioned in the DriverStore folder?
Also may or may not help but never had any problems with this,
SB Audigy Series Support Pack 3.8 (04/19/2010) - Creative Labs
on both an Audigy ES and an Audigy 4 (one running on 32 bit Windows and the other on 64 bit).
23 Oct 2010   #13
Ok I'll try to unistall all of those folders, and if doesn't work, i'll try that creative support pack. But I've a question:
I've had this High Definition Audio Device (in the first image you didn't see it because i had installed realtek for a moment) ->
since i've had my sound card, it has never created problems but i think is useless, 'cause it's a soft of microsoft audio but it doesn't play any sound. However I'll do nothing with this, for now.
In the FileRepository folder there are only these two folders which can be those you mentioned:
As you can see there is no "wdma_emu.inf_x86_neutral_" called folders
EDIT: I extracted that support pack, unistalled the drivers with that .exe, rebooted, installed the drivers, rebooted again, ran setup.exe, it installed everything, rebooted, nothing changed, the audio device was still with the yellow icon. So i right-clicked on it, press update, press manual and took the extracted support pack folder, it installed, but it seems like other drivers...the sound remains bad.
I think buying a new sound card is the right thing...But which to buy? I've 2.1 (it can be 3.1) system, and i want to spend as less as possible and I want to take another creative card, of course.
24 Oct 2010   #14
OMG I can't believe it! I installed again that support pack but without all that programs, only the driver, and it works fine! Thank you stormy13 !
Search this Thread:
Advanced Search
sound blaster audigy + m-audio fast track pro - remove?
Hello all! yesterday I bought a USB M-Audio Fast Track Pro for my "homestudio" and since I already have a soundcard in my machine SB Audigy I figured it might take load from the computer by removing the sb and just using my M-audio card Any advise please? Should I just go ahead and...
Cable for digital audio out for SB Audigy 2 card
I have a very old but very functional computer that I'd like to connect to my surround sound PC speakers. I currently have the computer connected to the speakers via the analog green, yellow and black cables, but my card states that it can support digital audio out, but I'm not sure what kind of...
Audigy 2 ZS and Microphone problem
Alright guys I am desperate, I have looked through countless websites, forums and advices. I recently added 2 Gigs of RAM to the 2 I already had in my computer running Windows 7 64bit. Once done, i found that my Microphone that was plugged in my Audigy 2 ZS sound card was making my voice sound...
New Xtreme Audio & Audigy SE/LS/Value drivers released
Creative has just released new drivers for both the PCI and PCI-E Xtreme Audio, as well as the Audigy SE/LS/value series of cards, Creative Sound Blaster audio driver 1.04.0090 released - Sound Blaster - Creative Labs - Audigy SE/LS/value Creative (PCI) Sound Blaster X-Fi Xtreme Audio driver...
SB Audigy 2 ZS Audio sound problem
i just installed win7 and i love it but sound sucks, i have SB Audigy 2 ZS Audio sound card, and i installed driver for it but my sound still sucks my problem is that i cant turn of 3D sound, i have stereo sennheiser headphones and when i play cod4 i only here on one speaker not the second one as...
Audigy SE to X-Fi Xtreme Audio
Just tried this mod but got the dreaded BSOD. Are there any new updates to this? Thanks in advanced!
