Windows 7: No audio output device is installed
20 Oct 2010   #21
Windows 10 Pro
Quote   Quote: Originally Posted by stormy13 View Post
Quote   Quote: Originally Posted by sygnus21 View Post
And lastly, can you post a link to your model of computer you have? Something with system specs?
Compaq Presario SR5129UK Desktop PC Product Specifications Compaq Presario SR5129UK Desktop PC - HP Customer Care (United States - English)
shows in his screen shot back in post #6.
Yeah, I see this isn't showing up in speccy or Device Manager....
Integrated Realtek ALC888S Audio
Which is why we ask if he's been in the BIOS.
20 Oct 2010   #22
Windows 7 Profesional 32 bit
Ive just gone into the bios and changed the onboard sound from auto to enabled then booted the PC up and windows automatically installed realtek for me and all is working fine I cant belive it was something so simple i take it by being on auto it was forcing me to use NVIDIA.
Thanks for all your help guys, a frustrating day comes to a happy end.
20 Oct 2010   #23
Windows 8.1 Pro RTM x64
You're welcome. I'm pleased that you have resolved your problem.
20 Oct 2010   #24
Windows 10 Pro
Happy to hear you looked into the BIOS and got it fixed
Search this Thread:
Advanced Search
No Audio Output Device is Installed
I believe this is an issue regarding an update. I had this issue before and did a system restore to back before I had installed a certain program, and the issue went away. Now however, I do not have a restore point that will go far enough back. I started up my computer today and I was hit...
no audio output device installed
This is my wife's sony vaio, and she has had this problem with no sound on her laptop, when checking the volume control it says no audio output device installed. In device manager it says that she has Intel display audio. I need major help here please.
No AUDIO OUTPUT DEVICE IS INSTALLED, this is the message l got on sound icone since l installed windows 7 l have downloaded it several time the latest one it shows on control panel but not on device manager, l guess this is not really installed but l keep installing it and restat the laptop...
No audio output device installed
I bought a generic computer. It had windows vista installed and it used to display a message that No audio output device is installed . I recently installed windows 7 home premium 32 bit on it but it still says the same thing. I went to properties of it and found following error message.This device...
No audio output device installed...Tried everything, need some help.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound Hi, I have had this problem now for a couple of months. What I have tried: Reinstall windows 7 Update bios Install the realtek high definition audio...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
