No audio output device is installed
RAFC1990
1:15 AM
This is the message i am getting at the bottom of my screen so i now have no audio. I re installed windows 7 but went from 64 to 32 bit and now i have no audio. I have looked everywere to download drivers etc but no luck.
I hope you can help.
Windows 7 Profesional 32 bit
Hi RAFC1990 and welcome to Windows 7 Forums :party:
Some specs would be useful, namely the make and full model number (including revision, if any) of your motherboard.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
I recently replaced my graphics card, that was the reason for the re install if that helps. Ive installed the graphics card drivers.
Motherboard is Asus PSLP - LE maybe P5LP - LE there seems to be results for both.
I can't seem to find a board with that reference. Are you sure that it's correct?
What does System Information have to say? I'm interested in the highlighted items, in particular the PNP Device ID shown in the second image.
Gigabyte IF233
Avast! 8.0.1497
IE 11
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Despite the number of results on Google pretty sure that PSLP-LE is a typo (that and the few links I checked that had pictures of it, it is the same as the P5LP-LE) and that this is the motherboard,
Motherboard Specifications, P5LP-LE (Leonite) - HP Customer Care (United States - English)
which if it is has the Realtek ALC888 on it and you can find links to the latest driver here,
http://www.sevenforums.com/sound-audio/3756-latest-realtek-hd-audio-driver-version.html
Ive downloaded them drivers they dont seem to do anything, on system information it just says im on NVIDIA :(
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
I cant afford the download mate,
I dont understand why there is no realtek driver when i have installed one just nvidia i think this is the problem.
Here is the Speccy setup
:ar:
on motherboard
6 pata Ide HD's & 2 Sata HD's
All Generic Full Towers
Fast Cable InterNet
Linked via TeamViewer !
Sorry seems there was a free link, image screenshot below.
The audio your seeing from Nvidia is from the video card, which has its own built in audio chip for passing audio over HDMI. Open the Windows playback properties and see if both the Realtek and Nvidia audio are showing, and if they are set the Realtek as the default playback device.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Go to Control Panel, Sound, click Playback tab....
As stormy said, you want to set yours to Realtek
Windows 10 ProIntel Core i7-4770K (3.5Ghz)32 gig Corsair Dominator Platinum (4x8Gig)Sapphire Tri-X R9 Fury
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
NEC PA242W 24" LCD Monitor
1920 x 1200
EVGA Supernova 1000 G2
Cooler Master HAF X
Logitech Wireless Wave
Logitech Performance MX
High Speed Cable
Norton Security
IE11
Apparently i have no audio devices installed :0
Er... yeah, that would be a problem.
Can you post a screenshot of your device manager?
Start, right click Computer, click Properties, in the top left hand corner click Device Manager.
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
1920 x 1200
Cooler Master HAF X
High Speed Cable
Norton Security
IE11
Yeh how come its saying that? Never had such a problem before!
Follow this,
http://www.sevenforums.com/tutorials/77614-device-manager-hidden-devices.html
to set Device manager to show hidden devices, then check the sound controllers again to see if the onboard Realtek has ever been detected. If it has it will be grayed out, if not it won't show at all. Next boot into the bios and make sure that the onboard audio is set to enabled (should be located somewhere the integrated peripherals section).
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
I see, (guessing) you've got you yellow exclamation marks, so that's good? With that said, they seem to be working, thus no yellow marks.
Can you right click on one of those, hit Properties, and post a screenshot of both the "General" tab and "Driver" tab?
Also, have you been messing around in your BIOS and disabled the soundcard by chance?
And lastly, can you post a link to your model of computer you have? Something with system specs?
Thanks.
Hmm.... I see me and stormy posted at the same time. Answer all the questions we both asked.
Thanks.
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
1920 x 1200
Cooler Master HAF X
High Speed Cable
Norton Security
IE11
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
