Windows 7: critical battery sound volume level?
20 Oct 2010   #1
eb2phkingood
win 7 ultimate 64
i have critical battery sound set on my laptop to turn on at 10% and then 7% and shut the computer down at 5% if i do not do anything about it. problem is, sometimes i have the volume real low or off and dont hear it. is it possible (in windows, not an external program, although i will look to externals if not) to set the volume at a standard when the critical alarm goes off? in example, my laptop is at volume 2, then it hits critical level of 10% battery left, i want the computer to automatically bump up the volume to 20 or 30 depending on what i choose. kinda nit picky i know, but hell i know it can be done, if not in windows surely someone can recommend a good program. thanks to everyone who takes time to read and reply. -n00b
21 Oct 2010   #2
fireberd
Windows 7/10 64 bit
You would need a special program just for that function, that whenever it needs to report the battery condition it would also raise the volume level. I've never seen anything like that. Have you tried doing a google search?
21 Oct 2010   #3
mckillwashere
Windows 7 x86/x64, Server 2008r2, Web Server 2008
You may be able to set something in task scheduler:
Condition = low power
action = Volume = %75
Action = play sound, or display on screen message
Action = Sound normal volume
Im not sure if you can set a condition like that but it could work.
22 Oct 2010   #4
eb2phkingood
win 7 ultimate 64
ok ill keep doin my homework on it. thanks everyone for your time!
22 Oct 2010   #5
LiquidSnak
W7 Professional x64
I believe that there is a program that instead of a tray notification, which I miss all the time, it gives you a large pop up. **searches the internet**
Customised alert sound for critical battery will not stop
I have set a customised alert sound for my Windows 8 laptop's Critical Battery alert but when I plug the charger in the sound keeps going. Is there a way I can have the sound play until the charger is plugged in and for it to then stop?
Disable automatic suspend on critical battery level
When my laptop is on critical battery level it suspends automatically. How do I avoid that? I want it to run until the battery is completely empty. Yes, I know I may lose data and damage the laptop; I do not care. I know the answer is somewhere around the POWERCFG utility but that thing is way...
Performance & Maintenance
battery level window
IN the past, I was able to have the battery level display open continuously. In W7, I can't figure out how to do this. I've found a gadget which displays battery, but it also displays other things that I'm not interested in having take up space.
Battery Level Jumps Up and down
Its strange but my battery goes from 16% to 23% (Or etc% To etc%) in one minute, once when I get down to about 10% I have to hurry and find my charger because that is no longer accurate.. Does this mean my battery wearing out? The battery and the computer is one year old.
Low system sound level, high music level?
Is there a chance do define two different audio levels? I guess I am not the only one listening to music with my computer - so I'd like to avoid awkward and looooud system sounds while turning up my stereo... is there a chance to do so? I know that apple has it, not sure bout win7... thx
Sound volume level's changing?
Driver version Realtek HD 2.23 drivers. When ever I go in the options settings of garrys mod it resets my speaker volume and garrys mod volume to 10% any idea why it would be doing this?
