I have to reverse my speakers position. (L is at R and vice versa)
  1. Posts : 387
    Win 7 & 10 x64
    IDK y but if I don't reverse my speakers, the sound from my games sounds reverse.
    For example. If I put my speakers in the proper order, sounds of bullet will come from my left speaker but actually it's coming from my right side and vice versa. This also happens on my old speakers and old computer and other games too.
    Is it just me?
  2. Posts : 2,009
    Windows 7 Ultimate x86
    Some games can reverse left and right in the audio options. So first check if you didn't click that by accident.
    If that's OK, go to Control panel/Sound/Speaker/Configure and run the test.
    If it comes up reversed, just unplug and switch the speakers .
    I have to reverse my speakers position. (L is at R and vice versa)-capture.png
    -DG
  3. Posts : 387
    Win 7 & 10 x64
    yea it comes out reverse because I reverse the speakers. But in games, reversing the speakers is normal for me. AFAIK, none of the games I play have reverse audio option such as BC2.
  4. Posts : 2,009
    you might have an option in your sound drivers that has been switched because I've never come across a game that had the sound reversed...then again, I don't play many FPS games...I'm more a D&D guy
  5. Posts : 387
    Win 7 & 10 x64
    Could it be just be my brain? since i also mention that this happens on my old computer too and with different speakers and different games.
  6. Posts : 908
    Windows 7 Home Premium
    If you're 100% positive the speakers are positioned correctly (they should me marked left/right) than it's possible the speakers were accidentally wired in reverse, which seems like the most likely scenario.
    Here's an easy test you can try, this will tell you if the speakers are correct.
    (unless they are USB speakers, then this test doesn't apply)
    Pull out the speaker plug, make sure the speakers are on and at a medium/low volume. Touch the tip of the plug with a finger, helps if you dampen the end of the finger first, a quick lick will do.
    You should hear static or a pop out of the LEFT speaker.
    Ap
  7. Posts : 55
    I've got same problem too. But in mine it's laptop built-in speaker so I can't reverse it
    Problem gone after I reinstall Windows and update drive
    I've got Realtek BTW
  8. Posts : 387
    Win 7 & 10 x64
    Ap
    it doesn't make any sound.
  9. Posts : 908
    Ap
    You have amplified speakers correct? Turn them up a bit, you should hear something out of the left side when you touch the tip of the speaker plug.
    Ap
  10. Posts : 387
    Win 7 & 10 x64
    Ap
    Ap
    yea I hear the popping noises in my left speaker, I have to turn it to max volume to hear it.
