Mic wont work on my Acer Aspire 4540 need help please????
chicogfx
12:00 PM
florida
hey whats yall Look i got a an acer Apire 4540 and randomly my mic stop working it was working properly until then all i hear is noise and not hear my voice if yall able to help me to get thru this problem i will much appreciated!!!!
ChicoGfx
Welcome to SF!
I suggest a system restore to get to a point before the troubles began.
Windows 7 Professional x64Intel i7 2600K OC'd @ 4620 MHz16GB GSkill Sniper 2133 Mhz (4x4GB)EVGA GeForce GTX 480 SuperClocked+
Asus P8Z68-V Pro
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
Well its been a problem for about 1 month doe but it was working until today i try to used skype and it aint working at all and hear all noice you think the system restore will work
Let me get this right: at first, the mic would only pick up noise. Now, it won't pick up anything at all. Is that correct?
Try uninstalling the drivers in Device Manager, and then installing these ones: Realtek
Also, download Ubuntu, and burn it to a CD, as per the instructions for a Live CD.
Download | Ubuntu
Try to record something. If it doesn't work, you may have a hardware problem.
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
Download | Ubuntu
>>>>>yup the mic was workin properly fine until this time it wont work at all friends of mine when i call tell me when i mak ea call and answer all they hear is noise thats why
Download | Ubuntu
if the problem stills what shud i do about the hardware problem take it to the place so they can able to fixed it
lOok i did what you say system restore and when i try the sound on skype like the record setup i hear my voice now but i hear noise and voice in between but i hear my voice now clearly just that noise is in between lols
If it is indeed a hardware problem, you can send it to Acer, if it's still under warranty. Otherwise, you'll need to take it to the local PC shop.
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
actually i got 1 more month soi think ima take it so i wont have any problems but thank you so much for your help!!!!!!
Alright, let us know how it goes!
Good luck chicogfx.
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
