No Sound EXCEPT through Media Player; Creative x-fi fatality
Scott2010
9:14 PM
Hey there. Man I have problems crop up with this computer more often than... oh nevermind.
Anyway, on to the issue. I'm not sure what happened, but now I have no sound at all except when playing files directly through Media Player. I checked the mixer and nothing is muted. There's no sound through IE8, or the sound control panel, or windows media center, or any games. But, playing songs, sounds, and videos through media player and they sound great.
I'm running Windows 7 Home Premium, using Creative X-Fi Fatality & 5.1 surround. I suspect it was some update, because everything was working just fine as of a couple of days ago. MS Tech support is out, because they want to charge $59. I'll reinstall my system before paying that.
Any help would be appreciated.
Windows 7 64 bitamd athlon 64 X2 5000+ dual-core 512k2GBGeForce 7900 GT 256mb ddr3/pci-e - X2
custom
Windows 7 64 bit
Asus Crosshair nforce 590 sli
2GB
creative labs x-fi fatality ed. 7.1 24-bit
ViewSonic
1 Maxtor diamondmax 10 300GB sata
1 WD 320GB ultra ata100
not sure
Nemesis
not sure
---Solved--- Window media center is messing it up. I'm guessing I don't have the audio connector bit configured properly. I restored to a point previous to dl'ing some updates, one of which was an update for wmc, and after restoring the sound was back. Testing wmc prompted for the program to be configured, and after configuring it the sound problems are back. Unfortunately, the 5.1 speakers I'm using have 3 plugs for the sound card, the options I get for the connections in wmc don't include the 3 plugs. So I'll just have to go by trial & error.
custom
Windows 7 64 bit
2GB
ViewSonic
not sure
Nemesis
not sure
Scratch that, it's not really solved. I went back and tried to configure the Media Center correctly, tried all the options for speaker setup and they all resulted in the same thing - no sound. So I went and removed the media center through program control, and still no sound. As a final go, I restored back to the same point I did in the above posting, and got the sound back to normal. Note the only thing I did in-between restores was try to configure wmc, so I'm guessing the problem has to be with that app. Yet, removing wmc didn't fix the problem, so I'm at a loss as to what's going on. Anyway the sound is up and working fine, and wmc is off my system, so I'm not messing with it any further. Doesn't make sense though...
custom
Windows 7 64 bit
2GB
ViewSonic
not sure
Nemesis
not sure
