Windows 7: Sound issues driving me crazy
11 Nov 2010   #11
Windows 7/10 64 bit
Video can be one of the most often causes. I have an ATI Radeon HD4850 video card and I can't use the last 3 versions due to some game problems. I would try several older versions and see if it makes any difference.
You could also give the "uninstall" a try. Uninstall the Video in the Device Manager (do not uninstall the drivers) then restart the PC and when Windows starts it will reinstall the Video. Sometimes this puts devices on a different shared IRQ which can make a difference. Go to the Device Manager, RIGHT click on the entry for the Video card to highlight it and then LEFT click on "uninstall" - restart the PC.
11 Nov 2010   #12
That didnt help, started straight after 1 game of call of duty this time :\ really starting to get annoying and there seems to be no way of fixing it
Dont know if this changes anything, ran it while i had high dpc latency
13 Nov 2010   #13
Just got 3 new things come up in the LAtencymon monitor tab..sigh i dont even know what to do anymore
USBPORT.SYS USB 1.1 & 2.0 Port Driver
dxgkrnl.sys DirectX Graphics Kernel
ataport.SYS ATAPI Driver extension
15 Nov 2010   #14
Win7 x64
That shows a list of different driver routines executing over 20ms. This gives the impression of a system which runs entirely slow. Possibly this is a throttling issue due to overheating. Please check your CPU speed with CPUZ and make sure it shows normal values before looking at anything else.
Search this Thread:
Advanced Search
Memory issues win 7 64 bit - Driving me crazy
Hi Guys, I wondered if someone would be able to help me with an issue which is driving me crazy today, I'm running Win 7 64 bit Ent with 8gb of RAM. I've got an issue where the system is caching around 5gb of that Ram, and no matter what I do I can't seem to get the system to release the...
Performance & Maintenance
Sound problem driving me crazy
ok,hello everyone I'm new here to 7forums and this is my first post...what am i doing here? well..I seek assistance I've had a sound problem for quite some time and I can't seem to solve it since I know virtually nothing about computers so please if would be kind emough to help me here's...
Nvidia driver installation issues driving me crazy!!!
I have a GTX295 and was using 190.38's with no problems. I decided to try the new 190.61's so I uninstalled the old drivers and also did a drivesweaper (guru3d) iteration. Then when I reboot WIN7 try's to install some lame driver and asks me to reboot again, if I try to install the 190.61's...
Graphic Cards
WMP driving me crazy!
I've got a strange problem with WMP and my music library. Whenever I open WMP, it begins to update itself. Its idea of an update is to make two to four copies of every song! This began when I tried to use Live Sync to sync my laptop (Vista) with my desktop (Seven)... it would see any...
Media Center
Two issues driving me crazy in Win7.
im trying to get used to win7 but I have some issues that are just killing the OS.... 1# How can I change the toolbar back to the old Win XP style? This new method is not only confusing but its a pain in the A, always forcing me 1 extra click (if there is more then 1 instance of that...
General Discussion
