No sound from the headsets
  1. sjf
    I have windows 7, clean install(upgrade), MOBO- ASUS P7P55D Pro. Intel I5 2.66, 2-2gig Corsair ddr3 Ram. 750w power supply 1tb hdd, 1-550gig hdd. Headsets- Cyber Snipa USB 5.1 surround headsets. I installed Beta Drivers from Cyber, I set the Headset program to use the headsets. I set the Audio program to use the headsets. No Sound card. All programs are up to date. Problem- No Sound from the headsets. I can, however, by using the control on the headset set the volume and mute. No matter what I have done I cannot get any sound from the headsets. Any suggestions would be greatly appreciated.I do not have speakers
    Thanks,
    Steve
  2. Posts : 13,354
    Windows 7 Professional x64
    Welcome to the Forums! Go to Control Panel>Sound and post a screenshot.
    https://www.sevenforums.com/tutorials...en-forums.html
  3. Posts : 2
    Windows 7 x64
    Hi i have been having the same issue with this headset after installing this driver. I tested the headset on a different Win7 pc and they work 100% fine without the driver installed, I then uninstalled it on my PC and there is still no sound.
