Hello all!
So, I've just installed a fresh version of Windows 7, coming from Ubuntu 10.04. Everything seems to work smoothly, except for the little problem of having NO SOUND! I've tried everything I can think of or find anywhere on the internet, and nothing seems to be making any difference. The sound symbol on my taskbar has a little red circle with an x, and it states "No audio output device is installed". I've downloaded oodles of
drivers (realtek, ones from HP, chipset
driver for intel as well as the nvidia one, ricoh card reader
driver, etc., all 32bit, which is what my win version is); some will install, some come up with errors, but neither seem to make any changes. Through device manager, I've disabled/enabled, uninstalled, deleted, had it check for
drivers. I've used windows update to see if perhaps it had any solutions. Nothing seems to work. Does anyone have any advice/ideas I could try? If you do, please use layman's terms to get there. I'm usually very good at troubleshooting, enough to get by with few problems most of the time, but I'm not up on all the technical terms. I can include screenshots of anything if it would help. I am on a Compaq Presario V3020US notebook, with an intel centrino duo processor. I'm not completely sure of other specs, but if you know where I can find them, I shall look there. ANY help would be appreciated. Thanks in advance!
~Asteria
