Another "No Audio Output Device is installed" Issue
Panosb
7:29 PM
Hey fellas,
So i decided to upgrade from XP pro 32bit to Windows 7 Ultimate x64 a few days ago.
Thats when my troubles began. Did everything by the book, clean install , install motheboard/vga drivers properlly.
Thing is i got that little devilish x on the speaker down right corner and since then i've looked over 500 solutions over the web forums including many bios changes like enabling and disabling the onboard HD audio and bios update also tried to install several audio drivers of my motherboards onboard sound chip like from other software or 32bit softwares.
Nothing worked and its all due to my system can't recognise the audio chip since im always getting "We can't find HD audio device" when i try to install the drivers.
In device manager i can only spot one option that might be the sound card and it goes by the name "High Definition Audio Controller". I've tried disabling it but nothing.When i try to uninstall it windows 7 automaticlly installs it back.
The motherboard is an ASRock P43DE with the VIA VT1708S audio chipset.
(i've checked on my motherboard and i noticed 2 chips near the audio panel. one saying VT1708S and another saying Realtek. But the Realtek chip might be of the LAN controler not sure about that)
In playback devices and recording deviced i get no option, complete black space.
So i am starting to get desperate after a few days of trying to solve this out because i was really excited about trying out my new software.
PS: Tried reinstalling windows but that didnt help.
Windows 7 Ultimate x64Intel E84004x1GB DDR2 667MHzNVidia 9600GT 512mb
Intel E8400
ASRock P43DE
4x1GB DDR2 667MHz
NVidia 9600GT 512mb
On board
Systems 1 and 2: Windows 7 Enterprise x64, Wi...System 1: i7 [email protected], System 2: AMD FX-41...System 1: 8GB System 2: 8GBSystem 1: ATI FirePro V4800 System 2: Radeon ...
Dell and Custom
System1: Viewsonic HDMI 24"
10 MBPS
Whenever im trying to install the audio drivers i get the "We can't find HD audio device" message.
btw i dont have the motherboard cd so im just using drivers from manufacturer's website.
Intel E8400
ASRock P43DE
4x1GB DDR2 667MHz
NVidia 9600GT 512mb
On board
Can you extract the audio file driver mentioned in the link above? Then go the the audio controller. Update driver, and select the folder you extracted the driver to.
Dell and Custom
10 MBPS
Yeah i've tried that many times. with the drivers of the link you mentioned and many other type of drivers like vista 64x drivers or even windows 7 x86 drivers.
I always get the "We can't find HD audio device" as i said.
When i run msinfo32 i cant see anythin at the audio tab also.
Intel E8400
ASRock P43DE
4x1GB DDR2 667MHz
NVidia 9600GT 512mb
On board
Panosb:
This may be too obvious but have you checked BIOS to make sure your onboard audio controller is enabled?
I don't know about others, but I always seem to forget the basics.
Windows 7 Home Premium x64AMD Phenom II X6 1600T16GB PC3-10700 (1342MHz)ATI Radeon 5770 HD (x2) CrossFire
OEM - Me
GigaByte GZ-990FXA-UD3
On-board RealTek chipset
3x Hanns-G 1920x1080 Monitors
Intel 25-V SSD 40GB: 218 MB/s AT: 0.1ms
Intel X-25M SSD 80GB: 230MB/s AT: 0.1ms
Seagate 750GB: 133 MB/s AT: 13ms (perpendicular storage)
Buffalo HD-PCTU3 1TB External drive
OCZ Stealth X Stream 750W
Cheap (unknown)
HP USB
LogiTech USB
1.5 Mbps - Slow - At the tail-end of a rural network
Printer: Epson Stylus C-84
Scanner: HP 3500C Flatbed
DVD-RW: Plextor
DVD-ROM: Unknown
WEI: 7.4
I've checked bios and it is Enabled and speakers were connected at all times ;<
Intel E8400
ASRock P43DE
4x1GB DDR2 667MHz
NVidia 9600GT 512mb
On board
If installing the audio driver from the asrock site didn't work, try reinstalling windows and adding the inf file from a flash drive in the load drivers option. It's likely that enough components were misidentified during the windows install that it really can't find your audio chip
Tried that aswell now. Still nothing .
Gonna try XP pro again just to be sure its not a hardware issue.
Im not ment to be with win7 it seems ;<
Intel E8400
ASRock P43DE
4x1GB DDR2 667MHz
NVidia 9600GT 512mb
On board
Not ideal, but you could buy an inexpensive sound card that is win 7 64-bit compatible.
Dell and Custom
10 MBPS
Not ideal indead.
Will update after i install XP pro just to make clear it is not a hardware problem in my mo/bo
Intel E8400
ASRock P43DE
4x1GB DDR2 667MHz
NVidia 9600GT 512mb
On board
Chances are it's not a hardware problem. Some hardware will not work in windows 7.. especially 64bit windows 7 ..regardless of how well it works in previous versions of windows.
Yeah but P43DE is Windows7 ready as it says in the site.
Dont know what to make of that.
When i google "No Audio Output Device is Installed" i get many results.
And that is disconcerning to be honest...shouldn't they release a service pack
allready ? I mean there are obviously compatibility issues for many sound chipsets or bios
versions or whatever.
Intel E8400
ASRock P43DE
4x1GB DDR2 667MHz
NVidia 9600GT 512mb
On board
Windows 7 SP1 will come out in 2011. There is a beta SP, but I wouldn't recommend it.
Dell and Custom
10 MBPS
Here's a thought.. try the sound driver for the P43DE3.. it wouldn't be the first time I've seen a vendor change a few components before creating a new model#
Unfortunatelly it didn't work.
They have the same size by the way so i think they are the same drivers as it is the same chipset or someting.
Intel E8400
ASRock P43DE
4x1GB DDR2 667MHz
NVidia 9600GT 512mb
On board
