No sound
  1. Posts : 2
    No sound
    hey guys.
    just installed the RC but have no sound, i went to the asrock website and downloaded the vista driver and run it in compatability mode now the red circle over the speaker symbol has gone but i still dont have any sound
    if i start up on my other HDD with vista on it, the sound still works fine so everything is working correctly.
    any ideas?
    all system info is in my profile
  2. Posts : 28,845
    Win 8 Release candidate 8400
    Guth
    You got the driver from realtek? Sound Card Motherboard - Realtek ALC888
    Did you check to make sure the volume slider (in systray) is not at 0?
    Did you go into control panel>sounds and check to see if your playback device is recognized?
    Let me know if that doesn't help
    Ken
  3. Posts : 2
    zigzag3143 said:
    Guth
    Ken
    yep the slider is not at 0.
    went to control panel and it says realtek high def audio, default device.
    there is a speaker with a tick and it says this device is working properly.
    im just wondering if i have installed the wrong driver or something.
    currently downloading another driver that is compatible with windows 7.
    will let you know how i get on
    thanks for the reply mate
