Switching Front stereo Left and Right Speakers
My cables for my front speakers can only go in reverse as the cable lengths!
Is there any software to switch L/R R/L :).
I have realtek HD Audio.
If the connectors for the speakers are standard connectors, get some extension cables.
The front right speaker is the problem. It uses a 15 pin connector to the sub. (vga like) the other is just standard.
If there is an extension cable ill get one! i cant find what i need? any links will help. I have the Green (stereo), Orange (center and sub), and black (rear stereo) connectors for my pc. An extension for that will work!.
Some sound card drivers actually have an option to swap the left and right channels in their Control Panel applet.
I think RealTek does (or used to).
Ive looked round all the software and there is no reverse stereo of calibration. i cant believe realtek have left something so simple out .
I guess ill just buy 3 seperate jack cable extensions
