Low system sound level, high music level?
questionesse
8:34 AM
Is there a chance do define two different audio levels?
I guess I am not the only one listening to music with my computer - so I'd like to avoid awkward and looooud system sounds while turning up my stereo...
is there a chance to do so? I know that apple has it, not sure bout win7...
thx
win7 prof.2GB
eee1000h
win7 prof.
2GB
I think I understand your question. I use powered partner speakers and in my audio controls for my sound card it has output levels and then and then my music manager has it's own. First I set my sound card at around 1/3 volume +- and then go to the mm and set a volume to around 1/2-3/4 full volume. Then at my speakers I adjust the volume to a clear but loud volume. Then going back to the mm I'll use it's volume only which is controlled off my keyboard and it seems to work well. You still will run into situations where things are too load or too soft and other than in your music files there really isn't much you can do about that, just be ready to ride your volume a little.
Windows 7 Ultimate 64
MSI P67A-GD80 b3
XFX Radeon 7870 2GB DDR5
Sound Blaster Z Series Card
1680 X 1050 p
(1) 1 tb WD Black
(2) 1 tb WD green/sata II
(2) 3 tb Seagate Barracuda
(1) 120 gb OCZ Vertex SS
(1) Drobo 5N w/5 Seagate 3tb
CoolerMaster Storm Styker
Basic 120mbps down
Chrome and IE 10
Netgear Nighthawk router
Asus USB 3 & sata 6 PCIe card
Drobo 5N advanced NAS
thx
Did you open the Mixer?? There's separate audio levels available depending on what applications you have open, System sounds are always listed separately AFAIK.
I don't use system sound so mine are lowered and muted, see pic.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
Yay - that looks good! didn't know they split the levels, must be a new option since xp - great!
Gonna try this later!
Thx!
win7 prof.2GB
eee1000h
win7 prof.
2GB
