Please help! HDMI audio not working
terri2403
6:02 AM
UK
Hi, first of all, I am new here so I really apologise if I have put this in the wrong place but I need help urgently. I have looked at another post similar to my problem but it didnt help me. I have recently installed windows 7 home premium 64bit on my sony vaio vgn-fz38m laptop. I had problems initially getting the graphics card to work but have managed that, my main use for my laptop is watching my edited/downloaded files on my plasma screen which with vista I had no problem connecting to via HDMI. Now since installing win7 I have had nothing but problems, I have tried disabling/enabling drivers and hardware and uninstall and reboot for windows updates to find the right driver and have just downloaded nvidia driver for HD but it says it cant find the driver so didnt install. I have picture fine through the HDMI but no audio,
Please can someone help me......
I am using nvidia geforce 8400m gt graphics and the sigmatel HD audio codec but the sound settings show my digital output (HDMI) as not plugged in.
I have googled and tried every known idea and I am hoping someone can help my specific problem.
windows 7 home premium 64bitintel core 2 duo processor t1800, tech 2.10ghz4gbnvidia geforce 8400m gt
sony vaio vgn-fz38m
4gb
IDT high definition audio codec
1280 x 800
200gb
OK so I did a system restore to a point when I got the sound working for a very short period. On start up I now have the HDMI codec as enabled and I have set it to default service, however the sound is still only coming from the laptop! I have tried test on the HDMI speakers and it says failed to play set tone.
Can someone please help me once and for all, as this is my third day of trying to configure my computer since the installation of windows 7, and I am getting really frustrated, especially as it was working briefly until I had to do an update then it disappeared again, hence first post....
Please help
sony vaio vgn-fz38m
4gb
1280 x 800
200gb
if you right-click the horn icon (next to the clock) and click "volume control options", what devices are listed?
windows 7 ultimate 64bitIntel Core2 Extreme x9000 2.8GHZ4Gig2 NVidia GeForce 8800M GTX (SLi)
Alienware AREA-51 M17x
Asus P965 Intel chipset
4Gig
onboard
17in. built-in, 47in JVC LCD
1080p
2 250Gig Hitachi (RAID 0) @ 7200RPM
17in. laptop
touchpad, Logitech Anywhere Mouse cordless laser
cable
Sorry taken so long to get back to you and thank you for your reply, I had to have a break but still no luck, here is what you asked for...
Speaker/Headphones which is ready and default device
and Digital Audio HDMI which is now 'not plugged in' again, the only way I could get this to work was by uninstalling the codec/controller but then still no sound being sent, so either way something not right. The trouble is whenever I do the uninstall and reboot my system doesnt like it and crashes after a period. :mad:
sony vaio vgn-fz38m
4gb
1280 x 800
200gb
what is the make and model# of your sound card?
can you fill in your system specifications?
4Gig
onboard
1080p
17in. laptop
cable
My specs are up, but it is a IDT high definition audio codec
sony vaio vgn-fz38m
4gb
1280 x 800
200gb
4Gig
onboard
1080p
17in. laptop
cable
Thanks, I have now figured out it was the graphics card not the sound card so I have rebooted in safe mode and uninstalled my nvidia geforce 8400m card then rebooted which reinstalled the original driver, so hope that side is sorted.
However, this was my original problem as I would like to obviously use my hd plasma and plug it into my laptop, so can I ask what driver you suggest to upgrade to that has compatibility and and for a dual monitor?
Thanks again for your help and I realise now this is in the wrong thread as its for sound and audio when actually its my graphics card but I wasn't aware at the time...
sony vaio vgn-fz38m
4gb
1280 x 800
200gb
i was assuming you upgraded from vista x64 to win7 x64. i tried checking sony's website for your model#, but couldnt since i dont have all the information required.
if there is a vista x64 driver available from sony, try installing it as you normally would. if you get an error, right-click the ".exe" file, select "properties", then the "compatibility" tab, then select the operating system that the driver was originally intended for (you could actually try them all if the first one doesnt work).
4Gig
onboard
1080p
17in. laptop
cable
Ok thanks, I will try and let you know
sony vaio vgn-fz38m
4gb
1280 x 800
200gb
