Windows 7: 5.1 Speaker System problem
01 Dec 2010   #1
chris10110
Windows 7 Home Premium 32bit
Recently purchased Logitech X 530
I have another set of these speakers on another computer with XP but I cannot get these speakers to work on Windows 7.
Help on how to get these working for windows 7 is much appreciated, thanks in advance.
The sub woofer works, just not the rear and center speakers
01 Dec 2010   #2
Ch@n
Please fill up your system specs to help you out.
What is the sound card you use? A 5.1? Is the cables properly plugged in?
02 Dec 2010   #3
chris10110
NOOB QUESTION ALERT:
Tell me where to find that and ill tell you
02 Dec 2010   #4
Ch@n
Goto UserCP and then Edit system spec
02 Dec 2010   #5
alphanumeric
Microsoft MVP
Windows 10 Education 64 bit
On some motherboards (like mine) the audio jacks do double function. For instance on mine the line in is also the output for the rear speakers. I have to change the settings in my Realtek Control Panel for all my speakers to work. If you have already done that you may want to look at the sound settings in control panel. Something else I've noticed is I have to check the Speaker Fill option in the Realtek Control Panel or I only get stereo playback in Windows Media Player when I play any of my MP3 files.
How can I find out which speaker system I have on my laptop
I'm installing a media player and it's asking if I have 2.0 Stereo or whatever on the list.
Powerful speaker system for my Asus Xonar D2X
I have an Asus Xonar D2X sound card for my rig and I am currently using a logitech X-540 speaker system. I'd like it if someone can recommend a really powerful speaker system that can be used with the sound card without the use of a receiver. I was looking into something better than logitech...
Is The Razer Mako 2.1 Speaker system good?
Hello everybody, I wanted to buy a good speaker. Is the Razer Mako a good speaker that deliver awesome quality of sound? I heard some bad comment and some good comment about this product. Can someone suggest me or give me some advice on this speaker or may you suggest a good speaker that I can...
Speaker System
Hi :) Now I have a better Computer I would like to play my music on it in my own room (Dads not keen on my music) anyway the speakers in my monitor are OK...ish but I would like something with a better bass, I found this setup, looks nice to me but I would appreciate some advice please, around...
Hardware & Devices
Realtek 5.1 speaker system problem
I have a 5.1 speaker installed and am currently running win7...i have used this 5.1 speakers from my previous xp...when i try to test the speakers, all are making sounds....but when i play music and watch movies only the front speakers and the bass are working...it doesnt make sense at all....i...
Drivers
Issue with Genius SW-5.1 1500 5.1 speaker system
Hi! I have a Genius Sound Maker Value 5.1 with a Genius SW-5.1 1500 5.1 surround speaker system attached to it. I downloaded the audio drivers from the C-media web page (the manufacturer of the that drivers) and both the Windows seven's control panel and in the set panel of the driver's...
