I here broken sounds. How do i fix this problem?
  1. Posts : 406
    windows7 Ultimate SP1 x32bit
    Hello buddies!
    Today when i playing Audio and video
    files some times every media files i here broken sounds (Windows Media player in windows 7). Then i play another files using windows media player then problem again happen. After that i run another files using Vlc media player. Problem still happen so what is the problem. If i change media player problem not fix.Then i listen that audio and video files using my head phone then i hear that broken sound. Audi and video files are not corrupted. Yesterday accidentally i clicked "IObi Toolbox" ,Fixed media player button" so is that the problem. If its sow how do i fix that problem?
    "IObi Toolbox" ,Fixed media player option re-register windows media player ".DLL" and ".OCX" files.
  2. Posts : 11,424
    Windows 7 Ultimate 64
    Restore your system back to a time it had clear sound.
  3. Posts : 406
    I'm not sure its the main reason. I only guess it. OK ill try it. Thanks!
  4. Posts : 406
    Not work! My PC don't have that time restore point.
  5. Posts : 11,424
    Are you hearing static like sounds or does the sound break up? When did this start, was the computer fine then all of sudden the sound went bad? I would try a previous restore point even beyond the start date, if you don't like the change you can revert back.
  6. Posts : 406
    I can't understand you mention static sound!
    This error not happen every time sometimes this error happen.
  7. Posts : 11,424
    I would restore your computer back to a point before this started.
  8. Posts : 406
    Now i repair my PC! Lets see after that!
  9. Posts : 11,424
    Good job, let's hope it stays fixed for a long time!
  10. Posts : 2,009
    Windows 7 Ultimate x86
    killer bee said:
    Yesterday accidentally i clicked "IObit Toolbox"....
    "IObit Toolbox" ,Fixed media player option re-register windows media player ".DLL" and ".OCX" files.
    Be careful with "accidental" clicks on programs like that.
    Chances are, all it does would be make you a regular in the problems section
    -DG
