Windows 7: The volume bar shows sound but no sound through speakers.
10 Jan 2015   #21
Windows 7, 32bit
Go to sound by either clicking control pannel, then type sound, or right click your audio icon in the right hand corner and click playback devices, go to your default audio device, hit properties, go to custom, and uncheck Digital Output.
31 Dec 2015   #22
Windows 7 64 bit
when my laptop suffer from similar problems like yours (volume bar shows sound but no sound through speakers)
I realize that I try ubuntu in my usb a while time ago, so I:
1. Shutdown my computer.
2. Plug in my ubuntu usb.
3. Turn on my computer, and press esc, to boot from usb.
4. I choose try ubuntu without installing.
5. While in ubuntu, I plug in the speaker and I adjust the volume bar to max, make sure that the plug-in speaker could produce sound.
6. I shut down the computer.
7. I remove the usb, and I turn on again the computer using the windows 7.
8. Now, the speaker could produce sound.
It is weird but I solve my problems using that.
06 Jan 2016   #23
I had this problem when I migrated from a HDD to an SSD. Sound completely stopped, even though the signal bar was jumping. For me, it turns out that I had to uninstall the drivers, then force Windows to generate a new copy of the driver file, specifically the HDaudio.sys file.
Located in \system32\drivers\, you'll have to first change the permissions to allow you to rename/delete the file. I followed this quick guide Take Ownership of file to ADD myself (a local Admin) to the full access permissions (I'm a Network guy, not a Sysadmin, I had no idea what a TrustedInstaller was!).
Once I had the permissions, I uninstalled the drivers, renamed the HDaudio.sys file, and rebooted. Automagically, I now have sound.
Hope this helps someone.
Search this Thread:
Advanced Search
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
No sound through speakers.Jack not being detected.HDMI sound only?
So I've got a problem,I changed my case 2 days ago and everything went great,all working as it should be.Up until an hour ago,when the lid got stuck in one of the little clips so after a quick bang it went in.But then I lost my picture on both monitors. So I went to investigate,I ended up...
no sound through tv via hdmi, sound plays through laptop speakers (idt
Yesterday I installed a new external hard drive - following the installation - my sound no longer played through my television (video is fine, HDMI connection) and sound now comes ONLY through the laptop speakers. The option for HDMI Audio doesn't appear in the 'sound' menus. I have 'checked'...
No sound from speakers or headphones, computer shows them as unplugged
Hello. The audio from my computer completely went dead when I turned it on. The speaker icon shows the symbol with the 'X' on it and after clicking it and going through the troubleshooter it can detect no problem. I tried updating the drivers through the HP website, and uninstall/reinstalled...
No sound from speakers but showing sound graph on speaker control
I have an MSI 785GTM-E45 Mother Board. I have no sound coming from the speakers. Tried new speakers and still no sound. If I click on the speaker Icon on the bottom right it shows the speaker graph going up and down as sound is being produced. I tried the head phones and nothing coming from them...
No sound from built in speakers, but sound from headphones
I have a Lenovo S10-3 Netbook, running on Win7 starter. It has been running fine unil a few days ago, when the built in speakers no longer play any sound. Works fine with earphones or exernal speakers, but not internal speakers. Drivers are all up to date, and audio/sound settings are all...
