The volume bar shows sound but no sound through speakers.
City Green
10:19 PM
I am pretty stumped with this one.
I upgraded my office to windows 7 32bit pro. 10 computers all the same, but one of them has audio issues.
When I play the sample music the volume bar shows the equalizer bouncing like it is sending out audio, but any speakers I plug into it produce no sound.
I have tried: different speakers, different jacks, 4 on the back 1 on the front, updating the audio driver, windows updates, rebooting, and yelling and now I am out of ideas.
When I use a usb based headphone I can get sound.
it lists the default sound device as a S/pdif high definition audio device...
Any suggestions on how to fix this?
Thanks.
Windows 7 pro 32 bite5200 intel2GNvidia NVS 295
e5200 intel
2G
Nvidia NVS 295
re: S/pdif high definition audio device
That's the digital output, you won't get any sound with that. Does it show "Speakers" listed in the same Window?
Right click on the Microsoft speaker icon in the taskbar, select playback devices, if you have Speakers listed, single left click on them and select "Set Default".
If you don't have speakers listed, make sure you have a pair of speakers plugged into the light green audio jack in the back then open the playback devices window as above... right click in the middle of the window and enable both "show disconnected/disabled devices".
Any speakers showing up yet?
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
it does not show any speakers listed, when I click show disconnected and disabled devices still nothing is shown.
When I plug in the usb head set a second icon does show up, and the configure button is able to be selected, but the configure button is not active when only the spdif connection is shown.
e5200 intel
2G
Nvidia NVS 295
At this point you can forgo any speaker, cable or jack testing as digital audio will output nothing.
With speakers plugged in and on, (green audio jack in back) go to Device Manager and un-install the audio driver, then reboot.
Also, you can try going to Control Panel/Programs and Features and see if your audio driver is listed there, if so, un-install and reboot.
What is the name of the audio system, Realtek, Conexant, VIA....?
If you look at one of the other office PCs you will probably see the speaker icon with the green default check mark beside it, this is what you need to see to get audio.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
tried both of those with no result.
I am not sure how to find the name of audio system.
I really appriciate your help on this, its confused me to no end.
e5200 intel
2G
Nvidia NVS 295
Finding the name of the audio system:
System Information/Components/Sound
(System Info is located in Accessories/System Tools)
Someone mentioned using the Windows 7 troubleshooter, might want to give that a try.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
Name High Definition Audio Device
Manufacturer Microsoft
Status OK
PNP Device ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0662&SUBSYS_1043837F&REV_1001\4&2C2530A5&0&0001
Driver c:\windows\system32\drivers\hdaudio.sys (6.1.7600.16385, 297.00 KB (304,128 bytes), 13/07/2009 4:51 PM)
e5200 intel
2G
Nvidia NVS 295
Status OK
Ok, that's a Realtek audio chip, same one that's on my motherboard (0662)
I suggest going to the Realtek site:
Realtek
And downloading the latest Realtek driver for the stubborn PC.
The one you want is the 6th driver from the top, first one in black ink.
File size 40765.
The first install may only remove the exisiting drivers... in that case reinstall them again.
Not sure about that as the drivers in there are Realtek/Microsoft drivers.
Check Device manager after the first install, you should see Realtek High Definition Audio.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
I tried that out. When I Installed the file it went through the process but when checking in device manager it still listed high definition audio device, it never updated to Realtek.
I installed flat out, then removed the current, then installed. I also tried removing then updating the driver from the location I had the new driver saved.
Nothing!
e5200 intel
2G
Nvidia NVS 295
Nothing!
I'm almost stumped... can you boot into the BIOS and see what it's set at for Audio, and what the choices are?
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
Have you checked the mixer window? make sure there are no types (line out, speakers, headphones, CD, WAV) that are muted. Make sure the fader is UP on each type.
windows 7 32Intel i7 4770KCorsair Vengeance 8gb DDR3 2133(PC3 17000)nVidia GTX 660 2gb
Homebuilt
windows 7 32
Intel i7 4770K
Asus Z97-A
nVidia GTX 660 2gb
Asus Xonar D1
Dell Ultrasharp UM2913WM
2560x1080 32
PNY 240gb SSD
Seagate 500gb SSD
Corsair CXM 600
Fractal Design Define R4
Arctic Freezer Xtreme rev 2
Logitech K800 Wireless Illuminated
MicroSoft 5000
Cable
IE 11 and Chrome
Samsung DVD-RW
Cambridge 4.1 speakers
Hauppauge HVR-950 USB Tuner
Asus Optimized Overclock to 4.4ghz
in the BIOS the HD Audio controler was set to [auto] the other option was [disabled]
Under front panel support it was set to [AC97] and the other option was [hd audio]
e5200 intel
2G
Nvidia NVS 295
If it's the Mixer with a low level I'm going to go out and kick a cinder block... but it could be.
Ok... if it wasn't the mixer... (whick I always forget about)
Set the audio to disabled, reboot, after the machine is settled reboot and get into the BIOS, set audio to Auto and set front panel support to HD Audio.
see what happens.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
I checked the mixer right off the start.
I tried changing around the bios settings and there was no change.
Also tried disabling the audio then installing the new driver, still nothing.
e5200 intel
2G
Nvidia NVS 295
Whimper...
Seriously, that's all I can think of, strange that your other machines work without problems.
Can you try plugging the speakers in the front panel "Blue" jack.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
I have tried every jack in the thing.
Is it possible that just the sound portion of the motherboard died?
e5200 intel
2G
Nvidia NVS 295
It is possible, was it working with XP?
Since I have the same audio chip, I'll post some graphics later this even, I have a gig in an hour.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
It was working in XP, but we did change the location of the computer after the upgrade...
Thanks again for the help, no rush.
e5200 intel
2G
Nvidia NVS 295
Doubtful that did anything... and you've tried more than one set of speakers.
Here's some related graphics.
What I show under "Playback Devices"
This is my "Communications" tab setting
Back to the first graphic with Speakers selected, the Configure Button, try the test, any sound?
Under the Properties button.
The Advanced tab.
The levels tab, notice I've scrolled down and have the "Front" level at 100%.
Disabled Enhancements, select Immediate mode first.
Under the Recording tab.
Considering you couldn't install the Realtek driver the problem may be hardware related, perhaps that motherboard has an older BIOS.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
e5200 intel
2G
Nvidia NVS 295
