Sound issues
  1. Posts : 384
    Sound issues
    My fiancée upgraded to Windows 7 a few months ago and all was working fine until a few weeks ago. Her onboard sound just stopped working for no reason. I have tried everything to fix this and it doesn't work. I have played sample sounds and the device says it is producing sound but nothing comes out of the speakers. (They work, tested on a laptop) Also there is no option for speakers anywhere. All that appears is High Definition Audio Device, it is enabled but nothing for speakers. This is doing my head in.
  2. Posts : 6,879
    Win 7 Ultimate x64
    If all that is showing is "High Definition Audio Device" then it is running on the default Windows driver and needs the actual driver for it installed.
  3. Posts : 384
    I tried that and nothing happened.
  4. Posts : 7,683
    Windows 10 Pro
    Have you been in the BIOS for any reason? Maybe you've disabled the on-board sound card?
    The other possibility is a Windows 7 update that might have mucked up the sound drivers.
    If that's the case then stormy's suggestion applies here...
    I'm quite sure he means get the driver for the on-board sound card.
    Check this post for some help/suggestions.... No audio output device is installed
    Let us know
  5. Posts : 384
    Didn't manage to get it working, all the drivers weren't compatible with windows 7. Azalia on board sound.
