Help setting up AAFP for Legacy Audio 97 for my front panel ports
  1. Posts : 889
    Windows 7 64 & Ubuntu 64
    I have 2 USB's, a firewire & mix & line in & out ports on the front of my computer case. (Origen Case)
    I've had it setup before & know it needs to be setup as Legacy Audio 97. But I had to unplug it to remove my processor & I forgot that they were all separate plugs & I dont remember what goes where.
    Black - L Out
    Green - Ret L
    Red - Mic in
    Yellow - Mic pwer
    Orange - R out
    White - Ground
    Tan - Ret L
    I can see where to put a couple like Mic pwer & ground, but a lot of the labels on the audio 97 config are labeled NC?
    So what goes where?
    Thanks.
    Attached Thumbnails Attached Thumbnails Help setting up AAFP for Legacy Audio 97 for my front panel ports-photo.jpg
  2. Posts : 1,927
    Does this diagram help. The connector in my diagram is upside down compared to yours but as you can see some pins are not used.
    Attached Thumbnails Attached Thumbnails Help setting up AAFP for Legacy Audio 97 for my front panel ports-ac97.jpg
  3. Posts : 889
    A little bit, but it still leaves a couple that I'm unsure of.
    Btw, all of the 7 plugs are all mini individual plugs, they arent together as one.
  4. Posts : 1,927
    JohnnyScience said:
    Black - L Out
    Green - Ret L
    Red - Mic in
    Yellow - Mic pwer
    Orange - R out
    White - Ground
    Tan - Ret L
    So what goes where?
    Thanks.
    You have 2 wires marked Ret L which one is Ret R tan or green?
  5. Posts : 889
    Commodore Pet said:
    JohnnyScience said:
    Black - L Out
    Green - Ret L
    Red - Mic in
    Yellow - Mic pwer
    Orange - R out
    White - Ground
    Tan - Ret L
    So what goes where?
    Thanks.
    Sorry Green is Ret R
    Tan is Ret L
  6. Posts : 1,927
    Using my drawing above.
    MIC-red GND-white
    MIC_BIAS-yellow NO CONNECTION
    FPOUT R-orange RET R-green
    NO CONNECTION NO CONNECTION
    FPOUT L-black RET L-tan
    try this and let me know how you make out.
  7. Posts : 889
    MIC-red GND-white
    Ok how can I tell if they are hooked up right, I dont have a mic?
    What should be coming from the Line Out ports?
    Can I hook a pair of headphones in them & hear music to test?
    It seems the USB ports already work even with out these addition 7 wires hooked up.
    I dont have a firewire to test the 1394.
    But I guess from reviewing your suggestions with the config the mobo manual says, you are probably right since the only ones that the mobo manual doesnt show are the FPOut R & L and placing them next to their R & L counterparts makes sense to me.
    I'll shut down the computer here in a couple minutes & try that wire config.
    Thanks.
  8. Posts : 1,927
    When I plugged a pair of headphones into my front port a popup appeared asking me if what I had plugged in was headphones, I confirmed and then it let me do a sound test which worked fine.
  9. Posts : 889
    Nice, I'll try it out.
  10. Posts : 889
    Ok they are all plugged in the correct spots. I tried to plug some headphones from my ihpone in both line outs & didnt hear anything.
    I may never end up using the ports, but its still nice to have them hooked up since they're there.
    I also need to hook up my firewire cable, but as is its not long enough to reach where it needs to go, probably needs another foot at least - I can buy an extension cable right?
    Just search for firewire extension cable?
    Attached Thumbnails Attached Thumbnails Help setting up AAFP for Legacy Audio 97 for my front panel ports-photo-1-.jpg
