Switched to 7 Ultimate, problems with Audio driver
diomedes
12:18 PM
Previously I was on XP, I just installed Windows 7 Ultimate 32bit on an alternate internal drive. All the drivers installed themselves, including a graphics card that gave me issues and internet too. But there's no audio.
Troubleshooter says:
Problems found: Hardware changes might not have been detected, Detected (yellow exclamation mark appears beside that line of text)
Above that it says The troubleshooter made some changes to your system. Try attempting the task you were trying to do before.
I don't really know where to start, could someone tell me how to fix this?
Thank you.
edit:
Trying to place a mp3 into winamp results in a message:Bad DirectSound driver. Please install proper drivers or select another device config. Error 88780078
Windows 7 Ultimate 32 bit
What sound card do you use?
Use Speccy to find out
Windows 10 Pro x64, Arch LinuxIntel Core 2 Quad Q8200 OC'd 3.08GHz8GB DDR2 900MhzMSI GT730 2GB GDDR5 (Kepler)
Asus Rampage formula LGA775
8GB DDR2 900Mhz
Supreme FX2
Samsung LS22F350 LED
1080P
Kingston SSDNow UV400 120GB, 500GB Hitachi, 2TB Samsung, 500GB Seagate FreeAgent, 640GB Samsung, 160GB Toshiba (Arch)
AeroCool 500W Bronze
Cooler Master V6 + 3X fans
Prolink keyboard
Logitech M705
1MiB/s
Chrome Beta
Thanks. It says no audio card detected, even though XP worked fine with sound and all. What's next?
Is it an onboard sound card and how old is it?
Go to the manufacturer's website and look for a windows 7 compatible driver and install it in safe mode
8GB DDR2 900Mhz
Supreme FX2
1080P
Prolink keyboard
Logitech M705
1MiB/s
Chrome Beta
I had the same problem and my OS is windows7 home premium 64bit. What you have to do that ......
1) restart your computer
2) press f8 when it restart
3) select 'repair my computer', press enter
4) select 'restore my computer( i am not sure the exact word, but it is a restore option )
5)Follow the steps(i forgot the steps, but it is easy and it will restore your computer)
6)restart your computer, then check your playback devices :)
Please let me know if these steps resolved your problem :))
