Sound won't work form Speakers but works in headphones
Ezom
8:56 AM
Hi everyone,
I have Sony Vaio CW26. Yesterday Sound stopped working from Speaker, it's still working from headphones. I tried to restore the system but the farther point I found was done 3 hours ago......
anyway, I found out too that the USB port ( which is next to the audio output) is not working too.
I checked the Device Manager and nothing is wrong, any ideas?
thanx.
Windows 7 home premium
Hi Ezom and welcome to SF!
That is most likely no driver problem. The way you described it makes me think it's a hardware issue.
Inside the headphone jack is a "micro switch that cuts the connection to the build in speakers as soon as anything is plugged in there. Sometimes those switches get stuck (especially if one uses headphone jacks that are slightly thicker than 3.5mm.
You could try plug/unplug the headphones (or a similar plug) several times to "unstuck" the switch
-DG
Windows 7 Ultimate x86DualCore AMD Athlon 64 X2, 2600 MHz 5200+Samsung 2GB DDR2Onboard NVIDIA GeForce 6150SE nForce 430
HP m8000n
Asus M2N68-LA (Narra)
Samsung 2GB DDR2
Onboard nVIDIA nForce 6100-430 (MCP61P)
Westinghouse 19" LED
1280x1024
SATA II Seagate Barracuda 500GB
USB II WD Elements 500GB
USB II WD My Book 1TB
USB II WD My Book 2TB
Stock (HP)
Stock (HP)
Logitech Classic KB 200
Standard HP opticle USB mouse
Still reading this thread?
I had this same problem, and your suggestion worked! Thanks for that. But someone from HP told me this could indicate a problem that might create a "short" in other components. Do you think this is true--that is, do you think this could go from an isolated (and apparently fixable) problem with the headphone jack to something bigger? I kind of just want to leave this alone...
In any case, thanks for the advice.
64 Bit Windows 7
HP/ EliteBook 8440p
64 Bit Windows 7
Hi SledgeDG, I signed up to these forums to say thank you. Your solution of plugging and unplugging the headphone jack solved my problem! :D TRODD
Windows XP
Windows XP
