Run Sound using key shortcut
  1. Posts : 18
    Windows 7 x64 - Linux Mint 10 x64
    Hey guys,
    An idea came to my mind, and i thought where's a better place to discuss than seven forums?
    my Q is that, what is the path for sound application? in the taskbar when you click on sound icon you get the sound window, it should be and .exe file that opens it, i wanna know the path to that exe file.
    my purpose is to assign a key shortcut to run that exe file, e.g. alt + s should open the sound window...
    how can i do this?
    thanking you in advance
  2. Posts : 6,349
    Many keyboards have shortcut "HOT" buttons built in and can be changed to do other tasks.
    I'm not sure the Vaio key board will do this. Click start> Device Manager> Keyboard> Hardware Tab>Properties.
    Or look for a "Settings Tab". Your Vaio manual at Sony might also have keyboard settings and explain set up for keys.
    Otherwise I'm sure it can be done like you are suggesting but I don't know the steps needed.
    Mike
  3. Posts : 18
    Yeah, there's a hot key for doing that, but it opens so SONY application, i want to open the default windows application for managing the sound. anyhow, I've reinstalled a fresh version of windows and i'm not gonna install all those VAIO crap again, they're just useless and memory consuming.
    anyways, thanks for your help Mike
  4. Posts : 6,349
    I was hoping Windows might give you some options in the Keyboard properties or settings.
    Check back someone else may come up with some suggestions.
    Mike
  5. Posts : 72,058
    Hello Alibahaloo,
    These Sounds shortcuts may be able to help. In addition, you could assign a keyboard shortcut to these shortcuts.
    Sound Shortcuts - Create
  6. Posts : 18
    Yeah, great... thanks for the link, i found the path:
    C:\Windows\System32\rundll32.exe shell32.dll,Control_RunDLL mmsys.cpl,,0
    having this as a shortcut will open the playback devices tap.
  7. Posts : 72,058
    You're most welcome Alibahaloo. :)
