Windows 7: Help setting up AAFP for Legacy Audio 97 for my front panel ports
10 Dec 2010   #11
JohnnyScience
Windows 7 64 & Ubuntu 64
Ok nevermind on the firewire, I found an extension cable for like 9 shipped.
10 Dec 2010   #12
Aphelion
Windows 7 Home Premium
NC = No Connection or something like that
Did they work before you disconnected them?
Ap
10 Dec 2010   #13
JohnnyScience
Quote   Quote: Originally Posted by Aphelion View Post
Ap
I think so? I never really tested them to be honest. I'm sure they're hooked up properly, seems to match the mobo schematics
Using both front panel audio and back panel: solutions
This possibly should go in the hardware forum since it involves the motherboard as well but being a sound issue I assume here would be better. I have an Asus Xonar DG sound card on an Asus P7P55D-E LX motherboard (and AMD Radeon HD 7800 Series video card) running on Windows 7 Home Premium...
Code 43 Error on Front Panel USB ports
Hi All, I am receiving a code 43 error on the two usb ports on the front panel of my desktop. These ports show up as unknown devices in my device manager and there is no driver data when i try and look at the driver information. However, when i try to update the drivers through windows...
Hardware & Devices
How to disable read audio panel and make the front panel primary?
Hello. I am having a not so common issue of a problematic REAR audio panel jack. The microphone pin got stuck and broken into the rear/back microphone jack and now the OS/driver thinks there is a microphone in the back panel but I just want to be able to make the microphone work on the front panel...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
Front Panel USB Ports
Hello everyone. The USB Ports on the front panel of my desktop connect to my motherboard using a wire. Now thats all fine and dandy but I do not know which to plug it into. The pin layout for the following (which match with the USB's cord) is this. . . . . . . . . . Now I have 3 of...
Hardware & Devices
sound/front panel ports
After my build, firs build btw, I have front panel mic/headphone ports. Also on my AC powered Altec Lansing speakers there is a headphone port. If I plug in my headphones into speaker port it mutes speaker and sound comes through headphones. When I plug in headphones into front paned ports I get...
