Sound gone
  1. Posts : 8
    Windows 7 64
    Sound gone
    This afternoon, I tried to listen to a local radio show on their stream, and I got no sound. I figured it was the player they have on the site, but then I tried to listen to another streaming radio show that uses Windows Media Player for Mp3s The player opens, the indicator starts moving, but no sound. I checked the volume control on the player - OK. I checked the speaker icon on the taskbar, and the green level line is going up and down, but I'm getting no sound. I tried some files on my hard drive, no sound. Real Player, no sound. All of them open and indicate there's a file being played, but I get no sound through the laptop speakers.
    This make any sense to anyone?
  2. Posts : 80
    Windows 7 Ultimate 64 bits
    Hi JonFrum. You should check if the sound card drivers are installed, maybe someone unistalled them.
  3. Posts : 3,139
    Check to make sure you haven't muted your sound.
  4. Posts : 1,927
    Ensure that you have the correct device enabled.
  5. Posts : 184
    Windows 7 Home Premium X64 SP1
    Do you have an 'actual' volume control anywhere on the laptop - like a wheel ? I had one on my last lappie - must have caught it one day and accidentally turned it down - didn't even know it was there! I had no sound for a few days until I found it. Doh!
  6. Posts : 3,139
    Yeah, I have a Dell with an external button mute.
  7. Posts : 8
    Windows 7 64
    The sound is not muted - it's a laptop, no sound card, no external volume knob - I ran the audio troubleshooting app from MS and it didn't find a problem.
  8. Posts : 544
    Windows 10 Home, 64 bit
    Did you recently install new software? Can you perform a system restore to the last time sound was working correctly?
    You're talking about a laptop, right? So there are no speaker cables to be plugged in--correct? I had a similar situation, and lo and behold, I tried everything. Then I looked at the back of the computer case--I had moved the computer a bit and the plug to the sound card simply came undone.
  9. Posts : 1,927
    Go into Control Panel. select Hardware and Sound, then select Manage Audio Devices under Sound. See what the default is under playback and let us know.
  10. Posts : 8
    Windows 7 64
    I restarted in Safe Mode and got the sound back eventually. I still don't know what caused the problem. Thanks for the suggestions.
