crysisdark
- Local time
- 3:49 PM
- Messages
- 3
hey guys! i'm new here, i just installed windows 7 yesterday, and i having a problem with my front audio pane both headphone and mic are not responding when i plug it in .i had Xp before, and the front panel worked without any problems, but now i can't get it working... tried the , newest driver, tried from bios (onboard audio ---enabled) and i cannot get it to work... there is one more thing when a put headphone jack in front panel it did no detect it but when i pluged mic into front panel just for a second i heard song for the headphone(which was i am playing that time),all is it just detect my headphone for a second that means it is working ,and plz dont tell me to "disable front audio detection" from realtk because all i get in my realtek manger is "enable jack detection when pluged-in"....so plz guys help me out ..i am not a computer genius so plz.....
and yes,this is my pc configuration:
right now i am using realtek Vista_Win7_R255 driver which is most updated
HardwareBase processor PentiumD 820 (S) DC 2.8 GHz
Chipset ATI Radeon Xpress 200 for Intel Processors
- 800 MHz front side bus
- Socket 775
- Manufacturer: ECS
- Motherboard Name: RC410-M
- HP/Compaq motherboard name: Asterope-GL8E
- Sound/AudioIntegrated High Definition audio
- Realtek ALC 883 chipset
- Supports up to 8 audio channels
- Dolby Pro Logic II compatible
Dolby 5.1 - External I/O portsI/O ports on the front panel
Port typeQuantity9-in-1 (4 slot) + 1 USBOne1394OneUSBTwoHeadphoneOneLine-inOneMicrophoneOne
Windows 7 Ultimate
- Windows 7 Ultimate
