Asus Xonar D2
  1. Posts : 12
    Win 7 RC x64
    Asus Xonar D2
    Hi there,
    Just got this soundcard for my desktop but not installed yet. I am installing it on a Win7 RC (x64) machine. Which driver should I use? Link please...
    Anyone tried all the apps that comes with it? Do they all work on the x64 or should I just skipém for now?
  2. Posts : 367
    Windows 7 Home Premium [64-Bit]
    Try this (Both Xp and Vista, should work on 7 too):
    Asus Xonar D2 / PM Audio Card Driver for Windows Vista - TechSpot Drivers
  3. Posts : 12
    Win 7 RC x64
    Thanks will give them a try. July 2008? Should be a more recent release or? Anyone know if they have beta drivers for Win7?
  4. Posts : 367
    Special drivers for Win7 are NOT needed. Let's not forget that seven was designed for more compatibility and speed, so your regular drivers that came on the CD or you found on the official website should work. Right now I don't see any drivers especially for seven on that soundcard. First try out the ones listed above and then I'll check if any new ones are gonna be coming out.
  5. Posts : 12
    Win 7 RC x64
    Thanks, will try the card the next couple of days. Will post success / failure...
  6. Posts : 6
    Windows 7 7201
    I've got the D2X (very similar) and the latest Beta drivers work fine (better than the stable drivers)
  7. Posts : 21
    Win7 RTM
    Just a note on Win7 build 7225. The most recent Xonar drivers for my DX seem to be broken in this release, while they worked fine on earlier builds. After installing the drivers and rebooting, Explorer windows would hang and require restarting the service. Removing the Xonar drivers cleared it up.
    I'm hoping it's just a quirk with that particular Win7 build since we'll most likely be waiting a while for Asus to update their driver sets.
  8. Posts : 3
    Windows 7 x64 Build 7229
    You don't need to remove drivers. It's the applications fault (soundmixer). Do a manual upgrade within "Device manager" and it will work just fine. Do not run the install. I also have an D2X and 7201 x64.
  9. Posts : 12
    Win 7 RC x64
    Ok so I am on 7100 and used 8.17 for Vista x64. Appear to work fine. No errors installing and sound is PHENOMENAL! Sure there are quirks with the drivers but my music library just got updated...
    I used this driver: Version 6.12.8.1764 for Vista x64
  10. Posts : 367
    Great! Glad to hear you solved your problem! Mind giving me some rep?
    It's shown how at the bottom of my post!
