Very strange problem, Help appreciated
Dotora
2:29 AM
Hey guys,
I have a strange problem that I cannot seem to work out.
Ever since I have installed RC1 64 bit my volume seems to change in volume at random, when windows 7 is first booted up the volume is fine but after that it goes up and down at will.
I have both a Audigy 4 24bit and Realtek ALC889A onboard. The volume changes happen on both the Audigy 4 and Realtek, it does not matter which I use.
I have tried all the latest Audigy 4 drivers including the ones for win7, my Realtek drivers are the ones that where in the windows automatic updater.
Im stumped as to what to do, its exreemly annoying as I cannot listen to music and it also makes gaming and being on vent quite difficult, as the volume is constantly changing.
Any suggestions would be fantastic
Thanks guys
Just to add one thing, this problem never occurred on on Win7 build 7000 64bit
Win7 RC1 64 bit
Win7 RC1 64 bit
try this
i think i has the same problem
i have found one thing that works i have not figured out the mic as of yet
seems to want to just reenable its self from a mute
but your sound problems sounds the same as mine when i started try this
click on the sound icon
click on mixxer
find system sounds on the mixxer
then click on the icon above the slider
you should end up on a multi tab window goto the last tab communications tab
set it to do nothing
that should fix the random volume changes
i made a quick tutorial
http://www.sevenforums.com/tutorials/13210-disable-system-audio-auto-leveling.html
Vista Business X64 / Win 7 RC X64 / Win t X64...Intel 2.26GHz Core 2 Duo Mobile P84004GB DDR3/1066NVIDIA® GeForce® 9800M GTS With 512 MB of GDDR3
Gateway P-7811 FX
Vista Business X64 / Win 7 RC X64 / Win t X64 RTM no activation
Intel PM45
4GB DDR3/1066
Conexant High Definition SmartAudio 221
17-inch WUXGA TFT (1920 × 1200)
1920 × 1200
200GB Seagate Momentus (7,200 rpm)
1.3 to 1.7-inches (H) × 15.75-inches (W) × 11.75-inches (D)
FIOS
This seems to have worked, THANK YOU.
I was actually looking at that option wondering what it did but never bothered to play with it.
Ill post here if I have anymore problems.
Win7 RC1 64 bit
Win7 RC1 64 bit
lol no problem at all glad i could help took me almost a week to find out what was doing that to me LOL
Gateway P-7811 FX
Intel PM45
4GB DDR3/1066
1920 × 1200
FIOS
Nope problem not fixed sigh...
Win7 RC1 64 bit
Win7 RC1 64 bit
o sorry then sorry i couldnt help
Gateway P-7811 FX
Intel PM45
4GB DDR3/1066
1920 × 1200
FIOS
