Does your case have front panel audio jacks? If yes, are they connected properly and setup correctly in the BIOS? My ASUS motherboard has two different configurations for the front panel audio, HD Audio and Legacy AC97. Also the cable to the front panel audio jacks in my case has two connectors, HD audio and Legacy AC97. I don't know what happens if you get these crossed but it probably wouldn't hurt to double check them. You appear to done everything else trying to fix your problem.
