HD Audio Deck BAD Problem
  1. Posts : 14
    Windows 7 Ultimate x32
    I just installed Windows 7 Ultimate x32 and the HD Audio Deck driver (asus P5KPL/1600 motherboard) but i have 2 major problems :
    1. While using the old driver that came with the cd i can't move the bass boost button and can't check Speaker Fill or anything else. Sound works but can't do the things i mentioned
    2. This is the worst : if i install the latest driver i will only get sound when using Winamp. If i run games or open music in media player the only sound will come from the subwoofer.
    I really need some help because i'm trying to solve this problem for the last 2 days
  2. Posts : 1,114
    Windows 7 Home Premium 64 bit
    You have to set up the sound in Windows as well as the sound in your music players
  3. Posts : 14
    how do i do that? i'm new to windows 7
    anyway, i don't think it's that, it's something more complicated
  4. Posts : 1,114
    Control panel/ sounds and audio
  5. Posts : 14
    it's configured...it has something to do with the DRIVERS !!!!!!!!!!
    UPDATE : now the new version of hd audio deck doesn't work either, no sound at all even though when i press the test button all speakers work
  6. Posts : 1,114
    You'll probably have to go to Asus website and get the correct drivers for the onboard sound, and make sure they are Win 7 compatible
  7. Posts : 14
    did you read my first post? i have the correct driver but it still doesn't work...i managed to make it work for about 20 seconds but that was it
    read this, maybe you'll understand better (a guy who has a similar problem)
    Hi... I recently switched my motherboard to Asus P5Q SE PLUS. This was also my first chance to hook up all of my logitech X-530 speakers. Music works fine, through all speakers when 'speaker fill' is enabled. In the past few hours i discovered another problem... I'm now unable to change any settings on VIA audio deck. It may show that speaker fill is switched off but it really is still working. And any other settings i try to make there, don't work. Like changing from 6 speaker configuration to 2 or changing from 16-b audio to 24-b. I can't make these changes anywhere anymore!
    When i play a movie (With VLC player) on my pc, i can hear all the background sounds+music but no voice. I changed from 5.1 to 2 front+2rear, the sound comes out from all speakers + subwoofer and i could hear the voice. Some movies, in the other hand, work nicely and i don't have to change any settings.
    The bigger problem is following: I play a lot of games... The first one I installed after switching the MOBO, was Operatin Flashpoint: Dragon Rising. I can hear ALL sounds from ALL speakers EXCEPT the voices. I can see subtitles though... Before switching my MOBO, i also had the game, ALL sounds worked perfectly, including voice. Same with movies. One difference is: My old mobo only supported 2.1
    Right now, i closed the VIA audio deck to open it again to solve a problem...I could see no options there. Most of the stuff was completely black. Now i'm unable to re-open the audio deck from control panel. I double click it, Nothing happens.
    Please help me find a solution to this!
    Edit: It looks like i have lost ALL control over the sound stuff. Any modification i do, even from the playback/recording tab that all PCs have. Totally out of control! Only the volume seems to be working :O
    It was fine at first, Everything used to work when i first installed the OS.
