Volume Mixer problems
psyxe
9:41 PM
Hello,
For some reason when I turn the system volume to 0, other programs do not also go down to zero.
In the volume mixer, when master volume is at full, other programs are at full too, and when I move the master volume slider down, the other sliders go down too...
However when master volume is at 0, I can still hear sounds from other programs (itunes, dvds, browsers) as if they are stuck at 1 volume and not 0
Setting the other sliders to 0 mutes them, and hence when I up the master volume, they stay at 0 and do not go up
Anyone having/solved this?
Vista Ultimate
Vista Ultimate
I installed Ventrilo recently, i've searched other places for ventrilo related issues and win7, i had no problems at all installing running and connecting ventrilo with a usb mic and without running in compatibility modes
This problem seems like it could be a major issue... i mean... volume shouldn't be coming out of anything if the master volume is set to 0
any word?
Vista Ultimate
Vista Ultimate
FIXED i think
reloading the drivers (realtek) seems to have fixed it, but im not sure if it was ventrilo that triggered the initial problem or something else
Vista Ultimate
Vista Ultimate
Another problem-volume mixer & lan (vista)
I can't seem to put the LAN and VOLUME MIXER icons on the Notification area of the toolbar. You know, at the system icons. The clock and power can be checked but the volume and the network can't. I'm thinking it was deleted but I don't know much about it or if it can be deleted. Maybe some virus can be the problem but my antivirus doesn't seem to detect anything! I even looked at the Device Manager and failed to find it. So I'm seeking for help!
Windows Vista
Windows Vista
@SpecifiedVista
right click on taskbar >> select tab "task bar" >> click button customize >> check "allways show all icons and notification on the taskbar" checkbox >> click OK
@psyxe
AFAIK
1. master volume slider and application volume sliders must be at the same level if you wannt to control all from master slider
2. applicatin level slider can not be higher then master slider
3. if app. slider is lower then master slider, then it will be so many times/places slower in moving then master.
Windows 7 Enterprise x64 SP1 Version 6.1 Buil...x64bit AMD Turion(tm) X2 Ultra Dual-Core Mobi...4096 (2048 + 2048) MB, DDR2 RAM (800 MHz), ma...ATI Mobility Radeon™ HD 3650+HyperMemory™(512...
Toshiba Satelite P300D 13J (Short model No: PSPDCE)
Windows 7 Enterprise x64 SP1 Version 6.1 Build 7601
x64bit AMD Turion(tm) X2 Ultra Dual-Core Mobile ZM-82
4096 (2048 + 2048) MB, DDR2 RAM (800 MHz), max 8,192 MB
ATI Mobility Radeon™ HD 3650+HyperMemory™(512MB VRAM+2302MB)
Manufacturer: harman/kardon
Generic PnP Monitor (MONITOR\LPLA101)
1440 x 900 (19" LCD)
HDD1: TOSHIBA MK3252GSX ATA Device (IDE 320 GB 5,400 o/min) ,
HDD2: Msft Virtual Disk SCSI Disk Device (Virtual Hard Drive),
HDD3: TOSHIBA MK3263GSX USB Device (USB Mobile HDD) (TakeMS MemLine)
Batery: technology : lithium-ion
integrated cooler + 3x external cooler
USB Logitech S520
USB Logitech S520
WAN: 7,2 Mbit/sec, WLAN: 54 Mbit/sec + Bluetooth®
