HD Audio Deck Disorted Sound
  1. Posts : 14
    Windows 7 Ultimate x32
    the only problem i have now is that some of the sounds are redirected to the subwoofer (like gun shots sound, explosions etc)..please someone help me fix this
    PS- the sound system has 3 jacks, green, red and black
    System specs? What sound do you have? e.g. RealTek, SigmaTel, SoundBlaster? What speaker system do you have?
    We can't really help you without some specifics.
    Coming from XP to Win 7, there are some hardware that may not be compatible. e.g. the old SoundMax (ADI) integrated audio does not have Vista/Win 7 drivers and the XP drivers are not compatible or not 100% compatible.
  3. Posts : 14
    Sorry, here are my specs :
    genius 5.1 surround sound system
    asus p5kpl/1600 motherboard with onboard sound card
    latest hd audio deck driver from their website
    i have an older post on this website with my last problems but i reinstalled windows since then and i'm only stuck with this 2 problems...i really need help...if i won't be able to fix this i will buy a new motherboard and sound card
  4. Posts : 8,135
    When you reinstalled, did you install the Intel motherboard chipset drivers? That is an often overlooked item and without it several devices including sound will not work or not work correctly.
  5. Posts : 14
    nope, not really...can i install it now, i mean will it fix the sound problem or should i install everything all over again?
    UPDATE : Nope, it doesn't work, most of the sounds still come from the subwoofer only and same thing with the equalizer from media player.
    PS - i need to mention that 2 days ago the sound worked normal when i installed the original audio deck driver from the cd but i couldn't enable bass boost or mark any other box
  6. Posts : 14
    here, some screenshots with the settings and stuff
  7. Posts : 14
    anyone?
  8. Posts : 14
    i read something about jacks, the order has been rearranged or something, can that be a problem?
    as i said, the only problem now is that some of the sounds are redirected to the subwoofer
