No audio output device installed...Tried everything, need some help.
Brydom
3:20 AM
No audio output device installed...Now fixed...Hardware issue.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound again...lol
Hi, I have had this problem now for a couple of months.
What I have tried:
Reinstall windows 7
Update bios
Install the realtek high definition audio drivers
I have looked in the bios to check if the problem was there
I have tried rebooting, updating drivers...etc
Now nothing has worked. I did have sound for the first 2 weeks or so. I need help please.....lol
My specs are:
Operating System
MS Windows 7 Ultimate 32-bit
Intel Mobile Core 2 Duo T5500 @ 1.66GHz 57 °C
Merom 65nm Technology
RAM
2.0GB Dual-Channel DDR2 @ 332MHz (5-5-5-15)
FUJITSU SIEMENS F43 (U2E1)
Graphics
Generic PnP Monitor @ 1280x800
Mobile Intel(R) 965 Express Chipset Family
156GB Western Digital WDC WD1600BEVS-07RST0 ATA Device (IDE) 38 °C
Optical Drives
HSPA USB SCSI CD-ROM USB Device
TSSTcorp CDDVDW TS-L632H ATA Device
Audio
Realtek High Definition Audio - (only because I reinstalled the driver from realtek website. It normaly says no audio output device installed)
Fujitsu Siemens Amilo Pi 2515
I just found this from another website, I don't know if it means anything:
Multimedia
description: Audio device
product: 82801H (ICH8 Family) HD Audio Controller
vendor: Intel Corporation
physical id: 1b
bus info: pci @ 0000:00:1 b.0
Version: 03
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list pciexpress
configuration: driver = HDA Intel latency = 0 module = snd_hda_intel
This is what should be in my laptop....?
Hiya pal and welcome to the forums. :)
It seems that you have the Realtek ALC883 sound card. Have a looky here pal ALC883 drivers ;)
Windows 7 Ultimate 64bitAMD Phenom Quad core 9950 black edition16Gb2x XFX Radeon 5850
Gigabyte
16Gb
2x XFX Radeon 5850
PCI Express X-Fi Titanium / Logitech G35
2x HP 2410i
2x 500Gb Seagate
1x 300Gb Seagate
1x 1Tb Seagate
2x 1Tb Hitatchi
Jean Tech Storm 700W
Cooler Master COSMOS S
Akasa Evo Blue Pro
Logitech G15
Mad Catz M.M.O. 7
12mb
Thanks...Its gonna take a long time to download for some reason...lol. I will let you know how things go.
Tried to install it but just said Does not support this Operating System:WNT_6.1P_32_MCE....What now?
This is bugging me...lol.
The original OS was Vista... I don't want to but I think I will have to go back to Vista...boohoo.
Please people I need help with this....
Any ideas?
7 ultimate x64Intel core i7 2600KVengeance™ — 16GB Triple Channel DDR3 PC16000GeForce GTX 560 Ti
CustomBuild001
7 ultimate x64
Intel core i7 2600K
ASUS P8Z68-V PRO
GeForce GTX 560 Ti
HannsG 22" widescreen (HDMI)
Samsung 1TB x2(RAID1) Deskstar 160G, Buffalo ExHD 500GB
Corsair 850HX
Antec Three Hundred Gaming Tower Case
CPU Freezer 7 Pro Rev. 2...ANTEC 3phase cooling, 2 intake.
microsoft intellitype 6000 v3.0
microsoft sidewinder
50Mb
64GB SSD in pipeline for Intel Smart Response Technology.
Try this one.
Realtek AC'97 Driver (Windows Vista / Windows 7) - Free software downloads and software reviews - CNET Download.com
If this doesn't work look in your control panel, check your sound devices etc.
I know this sounds like the first place you should look but i have done it myself where it has been disabled in my control panel, not having the icon in my system tray.
goto device manager and look for anything that may give you an idea.
Just installed it and nothing. Also looked in the device manager and nothing there. If I install the hd audio drivers it says "this device cannot start : Code 10".
I un installed everything to do with realtek and let win7 find and install them again. Getting no where fast. Its beginning to sound like a hardware problem.
do you know how to check your services?
check the windows audio service has started and its on automatic...
also have a look here for some troubleshooting
http://support.microsoft.com/kb/943104/
CustomBuild001
7 ultimate x64
Intel core i7 2600K
ASUS P8Z68-V PRO
GeForce GTX 560 Ti
Corsair 850HX
50Mb
Is the sound enabled in the BIOS? Also, did you install the Intel Motherboard chipset drivers? On many PC's the drivers must be installed BEFORE installing sound drivers or the sound drivers will not install.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Now....I checked the bios but found nothing about the realtek or multimedia or sound or anything like that. Where would I get the motherboard chipset drivers? I will do a search but don't really know what I am looking for:cry:...lol.
In most systems there is an entry in the BIOS, to allow disabling it if an external sound card is used. It may be labeled "legacy audio". But, if there is none in your BIOS then it's always enabled.
The PC vendor should have Chipset Drivers, either listed as Intel Chipset Drivers or Motherboard Chipset Drivers. One of the main thing the chipset drivers do is define all the hardware devices on the motherboard, which includes the sound module (chip). You could also do a web search for "Mobile Intel(R) 965 Express Chipset" I found THIS at Intel, go through the instructions to verify it is for your system and then download and install it.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Yeah, done that and nothing...lol. Going crazy here. :shock:
Might just go back to vista or just get a new laptop...lol.:D
